melody
#1 Posted : Friday, March 29, 2013 7:51:10 AM(UTC)
Rank: Guest
Groups: Guests
hi martin,
today i tested SpyDroid app in my android smartphone. it is a free prety cool application, very easy to customize, that send phone audio and video (from camera) via rtsp. it works very well with vlc (rtsp) and chrome/firefox (http). no need authentication.
unfortunately, i try to add rtsp in vmix it shows an error message "No Session". Error Report has been sended.
i realy want to test it on vmix. can you take a look on it?
regards,
melody
www.espiritosanto.cc
#2 Posted : Friday, March 29, 2013 8:43:53 AM(UTC)
Hi Melody,
I can't get the program to work at all with vlc on my phone. VLC just brings up errors.
vMix will report "No Session" if there are no streams available that support H264, which sounds like the case here.
melody
#3 Posted : Friday, March 29, 2013 12:58:34 PM(UTC)
Rank: Guest
Groups: Guests
the errors on vlc may be caused by audio encoding. try to disable, it works for me.
the settings i am using here are:
video codec - h263
bitrate - 5000kbps
fps - 20
cache size - 1000ms
just a question, the rtsp feature is based only on h264?
regards,
melody
#4 Posted : Friday, March 29, 2013 10:46:28 PM(UTC)
Yes, RTSP support is H264 only. H263 is an older codec and will not be supported.
