Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
Hi there,
I'm looking to create a script to change an input/output on a Blackmagic Videohub 40x40. I've been able to easily manage to do so via telnet directly (http://documents.blackmagicdesign.com/Videohub/20170424-bc33a9/Videohub_Installation.pdf towards the end - look for ethernet protocol section).
Looking for an example script to point me in the right direction. Essentially I'd like to have a script that sends the VideoHub the following via telnet on it's IP at port 9990:
VIDEO OUTPUT ROUTING: (carriage return) 7 2 (carriage return) (carriage return)
Any help would be greatly appreciated!
Thanks!
I've had no luck with this at all following vb.net telnet examples. Not sure if vMix scripting doesn't support, or I'm doing it wrong.
Here's what I am trying to do:
1) connect to x.x.x.x port 9990 2) send the following (<cr> indicates carriage return):
VIDEO OUTPUT ROUTING:<cr> 10 2<cr> <cr>
Then wait for either ACK or NAK as the response to indicate it was received and processed correctly or not, although frankly I'm not even concerned with response - it will be visually apparent if it worked or not.
Would love to see if someone is able to get this working...I've been at it for 2 hours here with no luck at all.
Thanks!
Thanks: 19 times Was thanked: 4 time(s) in 1 post(s)
I have made a DLL you can load as a title that will allow you to control a Black Magic video hub I have attached the full blend project and also just the DLL - hope this helps some people....  BMD v4.zip (6kb) downloaded 57 time(s). Telnet Control.zip (517kb) downloaded 67 time(s).
 4 users thanked smudge1977 for this useful post.
Originally Posted by: smudge1977  I have made a DLL you can load as a title that will allow you to control a Black Magic video hub I have attached the full blend project and also just the DLL - hope this helps some people....  BMD v4.zip (6kb) downloaded 57 time(s). Telnet Control.zip (517kb) downloaded 67 time(s). Hi smudge1977, Sorry to bring it up after all this time, but could you please explain how to use this DLL file?
Joined: 11/23/2019(UTC) Views messages in topic : 10  Location: Jerez de la Frontera Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
Originally Posted by: smudge1977  I have made a DLL you can load as a title that will allow you to control a Black Magic video hub I have attached the full blend project and also just the DLL - hope this helps some people....  BMD v4.zip (6kb) downloaded 57 time(s). Telnet Control.zip (517kb) downloaded 67 time(s). I´m interested.
