tdurhamjr
#1 Posted : Tuesday, July 4, 2017 9:52:50 AM(UTC)
tdurhamjr
Was thanked: 26 time(s) in 21 post(s)
I am hoping someone can help. I have a live event to stream in 2 days and I am getting an error message when trying to stream to the uStream service. I have never streamed to uStream but the group that is coming in uses that service and I told them that vMix would stream to it without any problems. Then when we did a test stream on Friday I got error messages :(
The error reads:
Name cannot begin with the '9' character, hexadecimal value 0x39
Line 25, position 5.
We were using the correct user name and password and it did not begin with 9. This seams to be a coding issue. Any help will be appreciated.
Tim
tdurhamjr attached the following image(s):
#2 Posted : Tuesday, July 4, 2017 10:40:41 AM(UTC)
@ tdurhamjr
Are you able to login with directly from a streaming encoder outside of vMix's Streaming module (Adobe FMLE or FFmpeg.org)?
tdurhamjr
#3 Posted : Tuesday, July 4, 2017 11:49:12 AM(UTC)
tdurhamjr
Ice, I will run up to the church and check it. A guy with the group we are streaming was able to login with no issues on the uStream page and he can use the uStream app with no problems. I will try to login with Adobe Flash encoder. I found another post from Bruce that he posted on June 30th and it appears that uStream made recent API changes. Hopefully Martin is working on an update for that.
I will post back after I run up there and check it.
Tim
tdurhamjr
#4 Posted : Tuesday, July 4, 2017 1:52:43 PM(UTC)
tdurhamjr
Ice,
I downloaded the uStream producer and installed it on the vMix PC. I can stream to uStream just fine using their software but not with vMix.
The group coming to our church Wednesday has a laptop with uStream Producer installed on it so I am just going to unplug our cameras from our vMix PC and let him plug them into their laptop. This is a one time gig so I will just let them stream it with their laptop. If uStream is no longer going to work with vMix it should be removed from the list :) But since I only use YouTube on a weekly basis the uStream issue is not a big one for me.
Thanks again!
Tim
