Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
Just updated my vMix and now I keep getting this when pressing the stream button:
Check the Stream Settings (such as URL and Key) are correct and try again.
FFMPEG.Exited Streaming [dshow @ 01f98440] Could not find video device with name [vMix Video] among source devices of type video. video=vMix Video:audio=vMix Audio: Input/output error
ffmpeg started on 2017-06-30 at 17:25:08 Report written to "C:\ProgramData\vMix\streaming\streaming 20170630-172508.log" ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.8.1 (rev2, Built by MinGW-W64 project) configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc libavutil 55. 2.100 / 55. 2.100 libavcodec 57. 3.100 / 57. 3.100 libavformat 57. 2.100 / 57. 2.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 9.100 / 6. 9.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.100 / 2. 0.100 libpostproc 54. 0.100 / 54. 0.100 [dshow @ 01f98440] Unable to BindToObject for vMix Video [dshow @ 01f98440] Could not find video device with name [vMix Video] among source devices of type video. video=vMix Video:audio=vMix Audio: Input/output error
Stream settings is fine and worked just before I updated vMix. I had this issue last weekend and had to do a system restore in Windows in order to get things working again. Obviously this is one way around it, but surely using the newest version of vMix should work aswell?
To what are you streaming and what are your settings? What version did you have before and what version are you using now?
- Tom
sinc747 wrote:To what are you streaming and what are your settings? What version did you have before and what version are you using now?
- Tom I'm streaming to a server we use for our tv channel, don't have access to the settings right now unfortunatley. Think the previous version was 19.0.0.46 or something like that, 4x I think at least. Trying to update to the latest, 19.0.0.54.
Actually, tried reinstalling vMix and got this error with some DLL-files:
Unable to register the DLL/OCX: RegSvr32 failed with exit code 0x3.
It's for vMixSampleSourceFilter.ax, vMixVideo.ax, vMixAlphaConverter.ax and MatroskaMuxer.ax
Not sure, but I wonder if this somehow could be connected to a recent Windows 10 update?
Just went over my paygrade. Suggest an email to vMix Support: info@vmix.com- Tom
Actually, the update was much bigger than I first thought... The previous version was 18.0.0.6x, so suspect it could have something to do with going from vMix 18 to 19?
