Good Morning,
Yesterday making a simultaneous stream to youtube and facebook live, an error was presented and the transmission to both servers was dropped. I do not know what the cause is and I would like to know if you can help me understand what has happened. I leave the streaming log when the error occurred. When stopping the streaming and setting the new facebook live key start the transmission and work perfectly the next 22 minutes until the transmission stops.
frame=66371 fps= 30 q=32.0 q=32.0 size= 173389kB time=00:37:00.07 bitrate= 639.8kbits/s
frame=66387 fps= 30 q=33.0 q=33.0 size= 173445kB time=00:37:00.56 bitrate= 639.9kbits/s
frame=66402 fps= 30 q=33.0 q=33.0 size= 173490kB time=00:37:01.07 bitrate= 639.9kbits/s
frame=66417 fps= 30 q=33.0 q=33.0 size= 173524kB time=00:37:01.58 bitrate= 639.9kbits/s
frame=66432 fps= 30 q=30.0 q=30.0 size= 173552kB time=00:37:02.07 bitrate= 639.8kbits/s
frame=66448 fps= 30 q=32.0 q=32.0 size= 173597kB time=00:37:02.59 bitrate= 639.8kbits/s
frame=66462 fps= 30 q=32.0 q=32.0 size= 173624kB time=00:37:03.10 bitrate= 639.8kbits/s
frame=66478 fps= 30 q=32.0 q=32.0 size= 173655kB time=00:37:03.61 bitrate= 639.8kbits/s
frame=66493 fps= 30 q=31.0 q=31.0 size= 173678kB time=00:37:04.10 bitrate= 639.7kbits/s
frame=66508 fps= 30 q=31.0 q=31.0 size= 173722kB time=00:37:04.61 bitrate= 639.7kbits/s
frame=66523 fps= 30 q=31.0 q=31.0 size= 173756kB time=00:37:05.12 bitrate= 639.7kbits/s
frame=66538 fps= 30 q=31.0 q=31.0 size= 173791kB time=00:37:05.61 bitrate= 639.7kbits/s
frame=66553 fps= 30 q=33.0 q=33.0 size= 173842kB time=00:37:06.13 bitrate= 639.7kbits/s
frame=66568 fps= 30 q=32.0 q=32.0 size= 173904kB time=00:37:06.62 bitrate= 639.8kbits/s
frame=66583 fps= 30 q=32.0 q=32.0 size= 173944kB time=00:37:07.13 bitrate= 639.8kbits/s
frame=66594 fps= 30 q=32.0 q=32.0 size= 173969kB time=00:37:07.58 bitrate= 639.8kbits/s
frame=66604 fps= 30 q=32.0 q=32.0 size= 173987kB time=00:37:08.13 bitrate= 639.7kbits/s
frame=66619 fps= 30 q=32.0 q=32.0 size= 174059kB time=00:37:08.64 bitrate= 639.8kbits/s
frame=66634 fps= 30 q=32.0 q=32.0 size= 174096kB time=00:37:09.13 bitrate= 639.8kbits/s
frame=66649 fps= 30 q=32.0 q=32.0 size= 174131kB time=00:37:09.67 bitrate= 639.8kbits/s
av_interleaved_write_frame(): Unknown error
[flv @ 04859720] Failed to update header with correct duration.
[flv @ 04859720] Failed to update header with correct filesize.
[flv @ 048a4360] Failed to update header with correct duration.
[flv @ 048a4360] Failed to update header with correct filesize.
frame=66650 fps= 30 q=-1.0 Lq=32.0 size= 174176kB time=00:37:09.75 bitrate= 639.9kbits/s
video:272580kB audio:69663kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
[libx264 @ 0485aea0] frame I:1150 Avg QP:25.47 size: 21512
[libx264 @ 0485aea0] frame P:65500 Avg QP:29.40 size: 1753
[libx264 @ 0485aea0] mb I I16..4: 47.0% 0.0% 53.0%
[libx264 @ 0485aea0] mb P I16..4: 1.2% 0.0% 0.1% P16..4: 18.9% 4.6% 0.8% 0.0% 0.0% skip:74.5%
[libx264 @ 0485aea0] coded y,uvDC,uvAC intra: 40.5% 47.5% 19.2% inter: 3.2% 8.7% 2.6%
[libx264 @ 0485aea0] i16 v,h,dc,p: 43% 29% 16% 12%
[libx264 @ 0485aea0] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 26% 17% 3% 7% 4% 7% 4% 7%
[libx264 @ 0485aea0] i8c dc,h,v,p: 52% 20% 24% 4%
[libx264 @ 0485aea0] kb/s:500.79
[libx264 @ 048a5260] frame I:1150 Avg QP:25.48 size: 21510
[libx264 @ 048a5260] frame P:65500 Avg QP:29.40 size: 1753
[libx264 @ 048a5260] mb I I16..4: 47.0% 0.0% 53.0%
[libx264 @ 048a5260] mb P I16..4: 1.2% 0.0% 0.1% P16..4: 18.9% 4.6% 0.8% 0.0% 0.0% skip:74.5%
[libx264 @ 048a5260] coded y,uvDC,uvAC intra: 40.6% 47.5% 19.2% inter: 3.2% 8.7% 2.6%
[libx264 @ 048a5260] i16 v,h,dc,p: 43% 29% 16% 12%
[libx264 @ 048a5260] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 26% 17% 3% 7% 4% 7% 4% 7%
[libx264 @ 048a5260] i8c dc,h,v,p: 52% 20% 24% 4%
[libx264 @ 048a5260] kb/s:500.78
Conversion failed!
I would appreciate if you help me understand what happened and how to solve it.
