element
#1 Posted : Friday, June 23, 2017 6:31:30 PM(UTC)
element
I have attached two images to help explain the results I am seeing, on the NDI image, look in the top left corner for the most pronounced areas.
Source and NDI should be the names, and in the source image you can see it is very clear and the divide between contrasting colors is smooth. On the NDI image, it has lots of compression artifacts and looks like the image is comprised of a bunch of small squares.
I am using 3 computers, one connected over HDMI to another with a capture card and that shows perfect quality, and then it is connected to the third computer using NDI to do the final encoding out to the stream.
It is a 1920x1080, 60 frames per second stream, and it shows around 140Mbs network usage. Also I have tested this going from all of the computers and they all show the same results. Even viewing the NDI source on the same computer with the NDI monitor shows this look.
Is NDI just not suitable for this quality or am I doing something else wrong?
Handles attachments
Source Capture (2).png (3,769kb) downloaded 57 time(s).
sinc747
#2 Posted : Friday, June 23, 2017 8:59:40 PM(UTC)
sinc747
Have you tested other resolutions/frame rates? That will help you determine where the issue is.
- Tom
element
#3 Posted : Friday, June 23, 2017 9:22:12 PM(UTC)
element
Hey Tom, yeah I have tried 1080/30 and 720/60 as well. Also both Intel and AMD systems and NVidia and AMD gpus.
- Tom
sinc747
#4 Posted : Friday, June 23, 2017 9:39:18 PM(UTC)
sinc747
NDI is mostly CPU. In fact, possibly may make no use of the GPU at all.
Surprising that lower resolution/frame rate has no effect.
- Tom
element
#5 Posted : Friday, June 23, 2017 9:46:52 PM(UTC)
element
Yeah, I'm using 6700k, 4930k and 1700x Ryzen, and ndi doesn't really put a load on them CPU wise. The NDI desktop capture has a GPU acceleration tab on it, so I just assumed there was some GPU usage too, but you are probably right. I've tried just the Intel CPUs too to. Ake sure it wasn't a Ryzen bug.
- Tom
kricher1964
#6 Posted : Friday, June 23, 2017 10:09:13 PM(UTC)
kricher1964
Was thanked: 13 time(s) in 4 post(s)
Have you tested with the free NDI monitor app from Newtek?
element
#7 Posted : Friday, June 23, 2017 10:12:27 PM(UTC)
element
Yes, I've tried vMix, NDI Monitor, ISO recorder and Xsplit. I've used them in different ways too like using xsplit to send the NDI feed and such.
stigaard
#8 Posted : Saturday, June 24, 2017 1:22:24 AM(UTC)
stigaard
Denmark
Are you sure that both PCs have Gigabit ethernet interfaces, and the switcher is also Gigabit? :-)
element
#9 Posted : Saturday, June 24, 2017 1:40:29 AM(UTC)
element
Yep, and speeds seem good on both ends, also sending a RTMP stream results in perfect quality footage but it is much harder on the CPU and I might as well just be sending out to twitch from there. Maybe it just isn't meant to transfer perfectly?
kane
#10 Posted : Saturday, June 24, 2017 1:58:14 AM(UTC)
kane
Are you using XSplit v2.9?
There is a bug in their software which is causing the compression issues when using NDI. I worked with the XSplit developers on this issue and they fixed it in a beta of 3.0. I've not tried the public release version, but try it see if it improves things.
Kane Peterson
NewTek
element
#11 Posted : Saturday, June 24, 2017 2:46:56 AM(UTC)
element
The xSplit is the newest version, 3.0 and I have used vMix to vMix, vMix to NDI Monitor, vMix to xSplit and more. I have tried 4 different computers as well, I think I might just be expecting too much from NDI as far as quality is concerned. There are a lot of contrasting colors.
Kane Peterson
NewTek
kane
#12 Posted : Saturday, June 24, 2017 12:10:25 PM(UTC)
kane
Kane Peterson
NewTek
I'd also give the vMix Desktop Capture tool a try or there is now a NDI plug-in for OBS.
https://obsproject.com/f...ugin-for-obs-studio.528/
NDI is able to handle this, but it all starts with the source capture application.
Kane Peterson
NewTek
NiBTour
#13 Posted : Wednesday, July 5, 2017 2:05:22 AM(UTC)
NiBTour
I have found that NDI isn't always the best option when doing eSport high fps type of games. In my lab i was able to use a 10Gbp pure network on two 4proc machines which was good but in no ways realistic and production worthy (in regards to cost for doing an acual event) so i have left NDI to less busy shots such as player cams and crowd cams unless i'm doing slower action games. NDI seems to be a great a solution for most but not all. I've been sticking with SDI for actual game captures. I've had issues with sound over NDI as well. Then again I've only used vMix so it could have nothing to do with NDI. Whats funny is how its said NDI is so cpu intensive yet i don't see it using much of CPU but bandwidth yes. I will soon be really pushing the specs of NDI seeing if it's a configuration issue with the network but i was using DELL PC 7048's and the 10Gb optical modules that were originally configured for an old iSCSI SAN so by no means an optimized solution but figured good enough being I've pushed 1.2GB a sec over that network for almost 1 years continuously with no dropped frames
zenvideo
#14 Posted : Saturday, July 8, 2017 5:10:10 AM(UTC)
zenvideo
NDI at 1920x1080 60fps can consume a lot of bandwidth, much more than 140Mb/s for a highly complex moving image, and the codec, whilst good, is not "unbreakable" in terms of image quality & artefacts.
I've just done a few tests at 1080p60 with my NDI Signal Generator, which was originally created to generate high bitrate NDI streams in order to test LAN+NDI application configurations and detect frame drops across a complex signal path. I've attached three image segments from the NDI Monitor & Task Manager, showing network usage and part of the test signal.
1) This is a moderately complex but mainly static image (apart from a barcode strip across the bottom of frame), but it's using ~250Mb/s and there is some visible degradation to the ZEN image.
2) This is a more complex moving pattern + barcode, apart from the ZEN image which remains static, and uses ~330Mb/s, producing visible degradation.
3) This is a much simpler static image, largely black plus the "Indian Head" test pattern and moving barcode, but even this uses ~150Mb/s, although the ZEN image is clean compared to the previous two images.
zenvideo attached the following image(s):
