colintve
#1 Posted : Wednesday, June 21, 2017 5:20:30 AM(UTC)
colintve
I would like to suggest that a new Input category is created which allows the user to select any of the outputs. We often need to see the multiple outputs that vMix can provide, and with the powerful switching and flexibility that shortcuts provide. BMD Atem mixers allow aux and other outputs in the multiview, so a replica of that basically.
Ittaidv
#2 Posted : Wednesday, June 21, 2017 7:10:16 PM(UTC)
Ittaidv
+1
cruiseweekTV
#3 Posted : Sunday, June 25, 2017 11:10:59 PM(UTC)
cruiseweekTV
Was thanked: 3 time(s) in 1 post(s)
+1
stigaard
#4 Posted : Monday, June 26, 2017 6:18:29 AM(UTC)
stigaard
Denmark
I'm pretty sure that what you requests is already possible in vMix.
You mention a multiview output - vMix already has this. You can use the multiview for Fullscreen and External.
As I understand, what you want is a input that is a multiview of inputs, you can easily do this by adding a new input by under Colour > Choose "Transparant", and then under the input settings Multiview, you can select which inputs you want, up to 10 layers/inputs, in the formation you want - several presets available. See http://www.vmix.com/help...utSettingsMultiView.html
stigaard
#5 Posted : Monday, June 26, 2017 8:18:35 AM(UTC)
stigaard
Denmark
That's some video-ception going on there :-)
