Hello, The last i see that the VMIX CPU rises to 100 or 120%. The result is stuck and clogged by the application, why? Thank you Apell
@ apell
You'll have to provide a little more info... Like system specs and scenario/profile when this happens. (kinda sounds looked a hardware issue/failure somewhere along the line, but too little info to go on)
Yes Sorry... My pc is a HP i5 and function in windows 10 . video codec in mp4 streaming with facebook. Thank you
@ apell
Are you recording as well? What do your logs say? Any other apps running in the bg? Any recent changes or updates to the PC and or your streaming profile?
Thanks: 2 times Was thanked: 4 time(s) in 3 post(s)
You are saying the CPU can go to 120%? Are you sure you are looking at CPU?
Right click your task bar and open task manager. Go to the resources tab. What is the CPU reading their? Go to the detail tab. Is vMix taking all the cpu?
Thank You Ice. No only stream,no record. Other apps no only the explorer chrome and 3 cameras,videos,images,line in for the sound etc... The CPU... this write in the windows of vmix app down (center) . image (now non function the vmix). apell attached the following image(s):  VMIX CPU.jpg (145kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
Is it a duo core i5 or a quad core i5? A duo core may not be up to 3 cameras and 25 inputs. Also, what are you capturing the output of the cameras with and what's the resolution and frame rate? Or are you utilizing USB webcams?
Hi SportsNetUSA.net, Yes is a PC int.c.i5 a quad core. It has 4 cameras usb and sound from line in and at the windows vmix there are multi videos and photos. I make live stream to facebook for 3 hours every day. Thank you for your help. Apell
