Thanks: 9 times Was thanked: 3 time(s) in 3 post(s)
Would it be possible to use the rode smart lav ( connects to smartphones ) via android ndi cam or iOS ndicam or through Zello t use as a cost affordable wireless lav ?
happy to report that NDI cam works very well using the rode smartlav mic( the cheaper smart lav is good but the + version is very good quality ,I've heard)
This makes for a wireless lav on a mobile phone for a stream where you have good wifi reception.
Rode also sell a little trrs adapter that allows you to plug in 2 mics and a headphone to your phone . If this works with vmix call it would be a nice improvement over using the internal phone mic. I 'll test and report back . If anybody knows of other solutions for raising the quality on a mobile hone call please let us know. Cormac
