Facebook Live streaming issues
Anyone know why I can post to my own facebook page but not able to post to other pages of which I have created or am assigned as editor?
vMix doesn't even create a log file.
I've been posting to these pages for weeks and just last week it wouldn't. Not sure if it is related to a vMix update. Can anyone with version 19.0.0.47 to .50 confirm for me that you're able to stream to Facebook Live pages other than your own timeline.
Thanks, John K.
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
I have the same problem, i can publish on every page from vmix until one and there is the same preferences setting, i don't understand, maybe the key is sometime not well understand by vmix ?
Joined: 6/29/2016(UTC) Posts: 104 Location: Luxembourg
Thanks: 48 times Was thanked: 14 time(s) in 12 post(s)
Had a similar issue some time ago.
First you need to check you are the admin of the page (not an editor)
Then the page needs to have a defined username (Settings) with an @.... This one also defines the URL
I was admin of a page but never cpould connect to it from vmix, while for other pages it worked, then I noticed the one setting that missed. Defined a username and it worked.
Hope that helps
Marc
A new message without anith_ing change : #2026 the live_broadcast feature is disabled for this application !"
Thanks: 3 times Was thanked: 10 time(s) in 10 post(s)
jmpaoli wrote:A new message without anith_ing change : #2026 the live_broadcast feature is disabled for this application !" I am also getting this for the first time today. Was working fine yesterday.
Hello everyone,
could you please help me, I'm in the trial version testing the program and message saying that the live broadcast feature disabled shown for me today with error number #2026
how i can solve it
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
jmpaoli wrote:A new message without anith_ing change : #2026 the live_broadcast feature is disabled for this application !" I can confirm the same error before and after the update to 19.0.0.50 . Thank you,
Rank: Staff
Groups: Registered, Administrators Joined: 12/13/2012(UTC) Posts: 244 Location: Gold Coast, Australia
Thanks: 7 times Was thanked: 160 time(s) in 73 post(s)
Hi, we're experiencing some streaming issues to Facebook Live that we're currently investigating. This is affecting the automated streaming option, but you can still stream manually with the stream URL and Key. Just follow the settings at the bottom of this guide. http://www.vmix.com/know...-facebook-live-with-vmix
 3 users thanked vmixsupport for this useful post.
Hello. Today i not can make live broandcast stream in facebook with V MIX. I bring you a picture too.  apell attached the following image(s):  error.jpg (45kb) downloaded 2 time(s).You cannot view/download attachments. Try to login or register.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Joined: 2/14/2016(UTC) Posts: 118  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
hola buen dia..tambien tengo el mismo problema que sera?
Anyone else having this issue? After many successful Facebook live streams, I'm getting this error message this morning. "#2006 The Live_broadcast feature is disabled for this application"
Is there a fix for this?
Any help appreciated,
Mike
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
Have you read the previous posts about the same topic?
Is there a younger one? I have to make a live stream VMIX on facebook... Thank you Apell
FYI. This issue is affecting other software products too.
Just updated to version 53, and it lost my facebook login information. logged in again, and it shows I am logged in, let's me setup a stream, but when I try to go live I get a error message "(2026) The live_broadcast feature is disabled for this application." I did a send error log to support.
Joined: 8/2/2013(UTC) Posts: 1,108   Location: Fairhope, Alabama USA Thanks: 603 times Was thanked: 204 time(s) in 170 post(s)
I understand that Facebook has changed its API which has caused this issue. For the time being, use the Custom RTMP Server stream settings for your Facebook Live stream. See also this vMix Forum post from vMix Support: https://forums.vmix.com/...ts&m=41157#post41157- Tom
