h2video.nl
#1 Posted : Wednesday, June 7, 2017 5:27:53 AM(UTC)
h2video.nl
upgraded vmix to 19 already, and this will included the latest desktop capture version also. but i also use a number of laptops with desktop capture only. also have it on usb, for quick deployment.
I thought i'd check the current version on my laptop and noticed it was old: v18 the new version was v19.
quickly replaced it. Would be good if the changelog also include notification of these kind of stand alone options and guidelines / alerst for upgrading, especially if the versions are incompatible, or have been upgraded / improved substantially. maybe a warning after an upgrade of the desktopcapture in vmix as is auto for vmix program.
stefan
