kgoodyer
#1 Posted : Tuesday, June 6, 2017 3:06:36 PM(UTC)
kgoodyer
Was thanked: 53 time(s) in 27 post(s)
Anybody know what may causes this...
I keep getting 'Unexpected Error, Recording Stopped' - however I am not recording, Just EXT (1920 x 1080 @ 25p to a decklink card) and STREAM @ 800Kbps (1024 x 576 @ 25p) using FMLE profile. NDI camera outputs are enabled and one NDI stream from the one SDI input it being taken by a sister VMIX system.
Inputs (Only 4) 1 x Decklink SDI input, 2 x NDI inputs, and a still image. Only using a NVIDIA Quadro2000D and a quad core 2.16Ghz XEON (not exactly a machine optimised for VMIX) with 8GB DDR3 DRAM- Only about 47% or CPU and 28% of GPU are being used. Works 99.999% of the time, but just get this error and all outputs stop once in a blue moon.
I'm sure the wording of this error is just misleading and should say 'All Outputs Stopped' but not sure where the issue lays, System bandwidth, CPU Bandwidth, Graphics Card resources, Memory? Where do I need to look.
This issue is repeatable on two identical systems. So has to be a common factor.
Better Graphics Card?
More CPU power?
More DRAM?
All The Best
Keith
kgoodyer attached the following image(s):
kgoodyer
#2 Posted : Thursday, June 8, 2017 3:36:39 AM(UTC)
kgoodyer
Anybhody? Martin - what does this error indicate when I am not recording?
#3 Posted : Thursday, June 8, 2017 9:35:53 AM(UTC)
This error means the Decklink output has stopped unexpectedly.
Most likely a problem with the decklink card, check the latest drivers for it are installed.
kgoodyer
#4 Posted : Thursday, June 8, 2017 6:14:21 PM(UTC)
kgoodyer
Thanks Martin - I will go checking in that area, swap the card out maybe, its an old Extreme 3D, ill try it with a regular duo instead.
Keith
Similar Topics
the underlying connection was closed an unexpected error occurrend on a send (General Discussion)
by Neuza Maria Tasca Da Silva 8/14/2022 5:25:40 AM(UTC)
