Need help with triggers/macros
Joined: 5/4/2016(UTC) Posts: 28 Location: Portland, Or
I have a sequence that I want todo at the opening of a show and I've got part of it down with triggers but I can't get it all the way through. The delay is not working at all on anything I'm trying. I am running vmix pro. I have a billboard for the begging of the show with a timer, when it reaches 0 I want to go to a blown up version of the logo and it start an audio track there is a 5 second count down at the begging of the track then I want it to cut to another input for a quick video and then to the intro video.
Is there a way to do this with triggers? On other systems you could record your keystrokes and it would repeat it as a macro. Is this possible for vmix?
