Feature Requests
Default bus settings for Inputs with audio
Hi, in setup you have an option to when adding an input to send audio to one of the Master, A or B buses. Could we have an option also for Master and A, Master and B as well as Master and A and B (basically all three).
I have a Church we installed a system into, the Master bus is live streaming and link to another hall, A bus is audio out into the church. So every time they and an input with audio they have to remember to select the A bus for that input.
Thank you
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
you can select any combination. Just click on M, A, B to de/select.
Hi yes, it is great that you can select/deselect the buses once the input has been created, but as the default bus for new inputs (under settings) when adding a new input I wish the option to be able to go to all three buses so that the operator does not have to remember to select the other buses once you have added the input.
Ah, now I understand (I think). Suggest you change the Subject of this topic to "Default bus settings for Inputs with audio".
And that what you are requesting is an addition to the Audio settings tab, which is something like: Default enable bus: [x] M, [ ] A, [ ] B
Nothing I currently need myself, but willing to +1 as I find it potentially useful.
 1 user thanked richardgatarski for this useful post.
Feature Requests
