WilliamJo
#1 Posted : Friday, June 2, 2017 7:43:37 PM(UTC)
WilliamJo
I installed the free version on my PC at home. It has a button for layers and works quite well. I installed the 60 day trial at our church, but it does not have the layers button in the lower right corner. Also, I am able to connect to our YouTube server from home, but it will not connect at the church.
Is it possible to uninstall the 60 day trial and re-install the free version? If so, how?
#2 Posted : Friday, June 2, 2017 8:25:41 PM(UTC)
@ WilliamJo
Can you provide a screenshot of the issue you are referring to? (not sure what the "layers button" is, perhaps you mean the "Overlay" settings button???)
It's unlikely there is a difference in the User Interface between the two versions, and if anything, the 60 day Trial is FULL Featured and will give you a better perspective on everything that the program can do.
I suspect there may be a screen resolution discrepancy between the two computers and/or system spec differences that is causing your "issues".
Can you provide more information about the computers?
AlanZ
#3 Posted : Friday, June 2, 2017 9:03:47 PM(UTC)
AlanZ
It is almost certainly a screen resolution issue. The overlay button disappears when windows display is set to lower resolutions.
WilliamJo
#4 Posted : Saturday, June 3, 2017 12:36:10 PM(UTC)
WilliamJo
You guys are good. You were correct - it was a screen resolution problem. Also, I said layers, when I meant overlay.
Thanks for the help.
