Damn2Good4U
#1 Posted : Tuesday, March 19, 2013 6:13:38 PM(UTC)
Damn2Good4U
Hello Martin,
Is there a way of doing vMix Hard Reset, should in case one made a mistake while adjusting some features, and vMix encounter an error whereby one cannot stream...
To quickly help in the cause of production, a hard reset I think will be an option to help individual users to reset vMix to its original fresh state, and one can quickly setup again without sending you log files all the time to determine a simple cause of issue..
e.g. selecting wrong audio or video setting etc.
regards,
Rottimmy
#2 Posted : Wednesday, March 20, 2013 4:22:36 AM(UTC)
Once you have the settings in vMix the way you want them you can go into Settings and click Export.
Then if you want to go back you can use the Import button to load those settings back in again.
Damn2Good4U
#3 Posted : Wednesday, March 20, 2013 6:01:09 AM(UTC)
Damn2Good4U
Thanks Martin,
This response is equally good...
Regards
Rottimmy
