vMix Social connect to IRC with Credentials
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
Hi!
Doing a show tonight with an live "IRC chat" from the livestream website Twitch.tv. It does have a IRC by default, however, it has to use a oauth token as channel name, and because I have no console, I see no way to connect to the wanted channel.
I successfully connected to the channel with mIRC using the token as password and joined the room via the console.
Any help is much appreciated! :)
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
At the moment vMix Social supports connecting to IRC servers and chat rooms that do not require a password. If the login you are referring to is the standard IRC password, then this will likely be added to a future release of vMix Social.
Martin vMix
Thanks: 23 times Was thanked: 3 time(s) in 3 post(s)
Hi Martin,
Is there any progress on this with adding support for IRC with logins - we are also looking for use with Twitch.
Jonny
