Nav
#1 Posted : Monday, March 18, 2013 3:50:48 AM(UTC)
Nav
I am using Vmix to play a swf which plays a live stream.
Is there any way to mute or adjust the audio for swf files? Although the swf input shows in the audio mixer the slider seems to have no effect.
Nav
thanks 1 user thanked Nav for this useful post.
Adriankey4 on 3/18/2013(UTC)
#2 Posted : Monday, March 18, 2013 8:37:16 AM(UTC)
Was thanked: 4645 time(s) in 1605 post(s)
Hi Nav,
Unfortunately the Adobe Flash Player does not provide any volume controls so vMix can't control the volume or mute of any SWF files.
I would suggest using the RTMP url directly if possible (as this has audio controls).
Nav
#3 Posted : Tuesday, March 19, 2013 7:36:40 AM(UTC)
Nav
Hi Martin,
Thanks for the info. I am experiencing some difficulty with rtmp streams. Our server path is something like:
rtmp://server.com/folderA/folderB/abc and the stream name is "stream".
If I enter rtmp://server.com/folderA/folderB/abc/stream in the AddInput->RTMP section I get an error.
The stream plays fine through a flash player - I am wondering if Vmix is able to handle rtmp paths with nested directories.
Nav
#4 Posted : Tuesday, March 19, 2013 9:40:29 AM(UTC)
vMix uses the Adobe built Strobe Media Playback swf internally for handling RTMP streams.
http://www.osmf.org/strobe_mediaplayback.html
You may need to refer to the documentation to work out how to format the URL.
You can also download the strobe media playback source and samples and try getting it working there first.
Nav
#5 Posted : Tuesday, March 19, 2013 11:41:37 AM(UTC)
Nav
Hi Martin,
I have worked out the required parameters for StrobeMediaPlayback following your suggestion:
streamType=live
urlIncludesFMSApplicationInstance=true
and additionally the rtmp src needs to be reformatted as:
rtmp://server.com/folderA/folderB/abc:stream
How can the parameters be passed to the StrobeMediaPlayback.swf in the "flash" folder?
Perhaps a parameter entry box in AddInput->Flash/RTMP would do the trick.
Nav
jwolthuis
#6 Posted : Tuesday, March 19, 2013 11:59:09 AM(UTC)
jwolthuis
Was thanked: 9 time(s) in 6 post(s)
Have you tried including the parameters with the URL?:
rtmp://server.com/folderA/folderB/abc:stream?streamType=live&urlIncludesFMSApplicationInstance=true
I think whatever you type in the existing entry box in AddInput->Flash/RTMP gets passed as the "src" flashvars attribute to the StrobeMediaPlayback object.
Jon
Nav
#7 Posted : Tuesday, March 19, 2013 1:35:42 PM(UTC)
Nav
Hi Jon,
Yes I have tried this - it doesn't work.
If you specify a .swf file instead of rtmp path then adding url parameters as you have described targets the swf file, not the underlying Strobe swf.
It appears that Vmix sends whatever is typed in as a "src" flashvars parameter, however what I am looking to do is send a different attribute altogether (not src). Martin could confirm if my understanding is correct.
Nav
