Showcase
Shooting from mast alternative
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
After receiving the wrong equipment (masts) at the location we had a creative carpenter fix something for us ( holding 2 remote heads with cams fro shooting 2 adjacent rings) nicknamed the gallows ;-) doggy attached the following image(s):  18643567_10100578792851561_1222836063_n.jpg (27kb) downloaded 18 time(s).You cannot view/download attachments. Try to login or register.
@ doggy
Sometimes, you just gotta do what you gotta do to get the job done... Great creativity on the spot! What is the overall height and how did it work in the end?
Height was roughly 4 meters (13ft) and worked out very well , very sturdy and stable (with added weights on the bottom plate ), easy to move. Stand and horizontal bit were 2 (lets call them ) 2 by 4's joined together with the top ones having holes drilled in to accept the pole bit of the heads (2 2x4 became sort of a clamp ) It's now in storage for next years event at same location :-)
@ Ice Found a shot of it in use :-) doggy attached the following image(s):  field.jpg (140kb) downloaded 3 time(s).You cannot view/download attachments. Try to login or register.
Showcase
