g33ks4d1
#1 Posted : Tuesday, May 23, 2017 5:01:01 AM(UTC)
g33ks4d1
Hello everybody...
this is my setup:
vMix HD
Intel Core i3 6100 2x3.70GHz (Skylake)
ASUS B150M-C D3
16GB Corsair Vengeance
240GB ADATA Premiere SP550 2,5" (OS/VMIX)
2TB HGST Ultrastar A7K2000 (Recording)
be quiet! Power B8 80+ 550W
Palit GeForce GTX 970 4096MB
Blackmagic Design DeckLink Duo 2
Blackmagic Design DeckLink Recorder
Ultron RealPower RPS19-4480, 4HE
MUSIC STORE 19" DD Pro Case 8HE 9mm Wood , 520mm
HANNS.G HL Series HL207DPB Monitor
Akai APCmini
Blackmagic Design HDMI to SDI (6x)
Blackmagic Design SDI to HDMI (3x)
Sony HDR-CX220E
Sony HDR-CX240E
Sony HDR-CX240E
Canon Legria R306HF
GoPro Hero 5 Black
GoPro Hero 4 Silver
GoPro Hero 4 Session
Silex DS510 (USB to ETH)
Logitech B565 (Webcam)
Logitech C270 (Webcam)
BenQ MH741 (4000lm)
5x3m Screen (4x2,5m 2x2m 2x1m Truss, 15m² mollitan)
Behringer 802 Xenyx for Audio Input Control
This last weekend i got the first wedding were i produced with this.
Really worked fine!
Take a look at the pics i made for you.
Feel free to rate my setup.
Little hint, on the right side is a Microsoft Surface Pro 4 with q-Light+, FX5 DMX Converter and an Novation Launchpad MK2 for DMX Light Control.
File Attachment(s):
g33ks4d1 attached the following image(s):
thanks 1 user thanked g33ks4d1 for this useful post.
G3racingMike on 10/10/2017(UTC)
#2 Posted : Tuesday, May 23, 2017 10:30:49 AM(UTC)
@ g33ks4d1
Cool set-up, thanks for sharing!
I'm curious about your choice of CPU and Motherboard though, can you elaborate on what kind of performance you are getting (vMix and overall CPU % use etc.)?
Are you Recording and/or Streaming from this PC?
g33ks4d1
#3 Posted : Tuesday, May 23, 2017 11:33:30 AM(UTC)
g33ks4d1
IceStream wrote:
@ g33ks4d1
Thanks.
Yeah i know that this is a bit downsized than the requirments for four cameras. I'm Recording, but not all the time. Only the programm and sketches of a wedding or anniversary.
Maybe i'm streaming once. But it is actually not requierd.
The next days i'll do some testing and show you the results of performance.
amylavonne
#4 Posted : Friday, September 8, 2017 2:59:42 PM(UTC)
amylavonne
Very cool, thanks for sharing your setup. I was searching the forum to see if I could use a gifted GoPro Hero5 camera with my new vMix setup. It looks like I can. It would be my third camera in my studio so I'm thinking about making it my "dog cam". Ha! I also have the AKAI APC Mini, but I haven't set it up yet.
g33ks4d1
#5 Posted : Thursday, October 5, 2017 4:30:40 AM(UTC)
g33ks4d1
Hi @all,
now i got some references. I know you had some concerns about the i3 with the performance, and you're right with it.
Last weekend i tried to use MultiCorder with 5 to 6 Cameras on the same time. And i got many findings from my setup. I was using 5 SDI Inputs (4 Camcorder and 1 GoPro5Black) and 1 Webcam. All together on my vMix PC worked fine, till i started to use Multicorder.
5 Cams MultiCorder: not really useable (nearly 100% both)
4 Cams MultiCorder: worked fine, but sometimes laggy (between 85% and 95%)
3 Cams MultiCorder: no problems (max 90%)
Every time i connected my webcam(s) to vMix (overLAN) the usage increased from 20% to nearly 50%. To use the MultiCorder with the webcams is possible, but depends on how much SDI inputs i'm recording at the same time. The table above includes SDI Inputs and webcam Cams.
To use an i3 with MultiCorder and Record (or Stream) at the same time, is not possible. The PC is laggy all the time both activated.
My summary: till i started to use the MultiCorder with an Intel i3 everything worked well (with 5 SDI inputs, 2 Webcams and many videos and pictures). But with this (for me) importent function, i've to upgrade to an Intel i7.
In the beginning of November I have the next event. Then I can share my knowledge with an Intel i7 with you.
