Help please: I need to change Web Zoom to %200????
Thanks: 2 times Was thanked: 2 time(s) in 1 post(s)
Is there a way to change the zoom factor of a web browser input? I want to do this to capture youtube comments without having to capture a whole display since it won't capture if used a chrome window.
best regards Basel
@ Basel
Does the Zoom Slider not work under "Position" setting (cog wheel->Position->Main->Zoom)
Yes, but the resolution suffers, I want to be able to zoom just like when you click control-Plus on Chrome
IceStream wrote:@ Basel
Could a CSS override do it? I'm not sure but if it could does vmix have CSS override option? I have that on xSplit, see the whole thing here is to save me from running xSplit while running vmix.
@ Basel
Perhaps a "Feature Request" is in order to be able to access that feature of the Browser, as I don't know how do this within the "Input Browser" in vMix.
it's very odd no one seems to care about this, I think it's very essential to anyone who uses a web browser input! that is if you ever care about picture quality....
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
I don't believe nobody cares, maybe no one has had that issue or need ?? It seems logical that if you zoom you loose quality , same with video but maybe you should try this: First zoom the page itself in your browser and than crop the part out you want in vMix. That does improve the quality of a smaller part of the browser capture Browser zoom
@ doggy
I think Basel is referring to the Browser Input within vMix, it does not offer the same options as found on a regular windows browser.
@ Basel & Ice; Sorry for getting the referencing wrong
