Recording timed out waiting for first frame - MultiCorder
Trying to record an NDI Input (PC running Powerpoint) on vMix
When I click on START on MultiCorder (or click the MultiCorder icon on vMix to start the recording) I get the error:
Recording timed out waiting for first frame. MC_OK.Buffer_WFF
The logs report:
ffmpeg started on 2017-05-16 at 15:56:19 Report written to "I:\\MultiCorder2 - NDI PP-PC (Microsoft PowerPoint) - 16 May 2017 - 03-56-19 PM - 00000.ts.log" Command line: "C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg.exe" -report -y -f asf -i "\\\\.\\pipe\\34472dc1-982b-4013-a009-8611646fd24c" -r 15 -pix_fmt yuv420p -vcodec mpeg2video -maxrate:v 8M -minrate:v 8M -b:v 8M -acodec mp2 -b:a 128k -f mpegts "I:\\\\MultiCorder2 - NDI PP-PC (Microsoft PowerPoint) - 16 May 2017 - 03-56-19 PM - 00000.ts" ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.8.1 (rev2, Built by MinGW-W64 project) configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc libavutil 55. 2.100 / 55. 2.100 libavcodec 57. 3.100 / 57. 3.100 libavformat 57. 2.100 / 57. 2.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 9.100 / 6. 9.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.100 / 2. 0.100 libpostproc 54. 0.100 / 54. 0.100 \\.\pipe\34472dc1-982b-4013-a009-8611646fd24c: Invalid data found when processing input
First time using MultiCorder (just upgraded to 4k from HD) Nothing else is recording/streaming at this point, just recently rebooted, drivers appear to be latest versions, Windows 10, vmix 19.0.0.47. Happens whether it's my main broadcast vmix save file, or a brand new blank setup.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Hi, Unfortunately NDI sources that use desktop capture are not supported by MultiCorder at this time. The reason being that desktop capture frame rates can be lower than 1 frame per second, which is the minimum requirement for MultiCorder to work. If you play a video in powerpoint as a test, it should start recording correctly, but while the image is static it will not. As an alternative you can use the free NDI IsoCorder application to record the desktop capture instead. https://www.newtek.com/ndi/applications/Regards, Martin vMix
