Joined: 7/4/2015(UTC) Posts: 65   Thanks: 3 times Was thanked: 3 time(s) in 3 post(s)
Would love to see a cue system editor built into vmix so you can edit the track (video) before you play it on air kinda like what you can do with music maybe in the future of release
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ wtmuradiotv
Can you elaborate? Are you talking about cueing a video by referencing the audio therein? (because you can visually "edit" the IN and OUT points of a Video Input from the PREVIEW screen)
A editor built into the program so you may edit the video before placed for play ...Kinda like what a program i am currently using at this time radiodj ...You should be able to cue starting points and ends
Not the way i would like to see take a look at radiodj and see what i mean by cuing the point ...Video editing shouldn't be done from the base of the program it should be done by a real editing part of the program not the interface there should be a screen you can go into to edit the video or whatever your gonna play so that you can cut whatever you want off ...The interface of vmix editing is sloppy the cue point drifts back and moves .Just like other editing you need a start and stop point and it has to be tight ! Also would love to see them use sql so videos don't lay heavy on the program itself that would be ideal
