spino
#1 Posted : Sunday, May 14, 2017 10:19:27 AM(UTC)
spino
Italy
Was thanked: 21 time(s) in 13 post(s)
I've a question about VLC on NDI.
I'm thinking to use a second PC just to send some videoclips to Vmix installed on the main PC and I found that a great solution is to use a playlist in VLC on the second PC to send via NDI the clips to Vmix. Everything works perfect but there is a little problem I can't solve. If I put the second PC in another room managed by an operator (not me) that operator can't monitoring on his screen the video he's sending because in VLC settings the output is set on NDI. Any advice to solve this problem? (I know, I could use desktop capture to capture the video and audio coming from VLC on second PC but why have I to renounce at the feature and the quality of NDI?).
I apologize because I know that it's a problem relating to VLC and not Vmix but I think that a possible solution could be useful for everyone.
Thank you in advance for any advice.
Lino
#2 Posted : Sunday, May 14, 2017 10:24:27 AM(UTC)
Hey Lino!
2 options:
- NDI Monitor from Newtek, free and reliable (you problably already have it installed as it is part of the NDI Tools package)
- vMix UTC which integrates NDI Monitoring
Guillaume
spino
#3 Posted : Sunday, May 14, 2017 10:34:26 AM(UTC)
spino
Italy
DWAM wrote:
Hey Lino!
2 options:
Guillaume
I hadn't any doubt that Guillaume has a solution for everything regarding Vmix. Thank you so much, both the solutions work great.
