imagebotique
#1 Posted : Wednesday, May 10, 2017 6:09:34 PM(UTC)
imagebotique
I am trying to use a PreSonus Faderport which has several buttons on it and a single audio fader and I have tried to map that to the audio level for a camera microphone through the use of a Shortcut but I am unable to get it to work. This unit is one I am just borrowing from a friend as I am more interested in getting something like a Behringer X-Touch USB controller which has 8 motorized faders found here at this link https://www.bhphotovideo...sal_control_surface.html I am wondering if perhaps this PreSonus may just not be compatible with Vmix as a MIDI controller or maybe I am setting it up wrong. Should I proceed with the Behringer purchase? Any advice on how these types of music devices work to control the level of multiple camera audio sources?
SportsNetUSA.net
#2 Posted : Thursday, May 11, 2017 7:05:28 PM(UTC)
SportsNetUSA.net
Tom Sinclair did a video about using a Korg midi device to control audio, and the T-Bar. Perhaps you can use the info and apply it to the PreSonus Faderport.
https://www.youtube.com/watch?v=D0palug7MKY
imagebotique
#3 Posted : Friday, May 12, 2017 10:00:38 AM(UTC)
imagebotique
Following that video was easy and I was able to get my faderport fader to control the T-bar in Vmix with no problem however getting it to control the volume level of a camera does not seem to work.
Key/Control is set to MIDINoteON
Channel 1, Note 0, I have tried various values on the Value field
Function is set to Set Volume
I have selected a camera input next
The value input box I have tried having that empty as well as entering 0-100
I have successfully mapped buttons on the faderport to Mute/Unmute for example and it works fine. I just can't get the fader to move the volume control up and down on the camera input in vmix
