Hardware Compatibility
Yuan M.2 SDI Capture for Tiny Capture Builds
Joined: 4/4/2016(UTC) Posts: 236  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
I found this today when I was researching capture devices. Yuan M.2 SDI Capture http://www.yuan.com.tw/e...di_hdv_b_m_keys_spec.htmThought you guys might enjoy it for tiny capture builds. I think it would make a great NDI remote capture box build. Drop it in a Intel NUC and off you go. If anyone has used it let me know as I am interested to know how it works. Since the bandwidth is there I think a 4K capture would be unbelievable in the M.2 form factor. I also think that is at least 2 years away if ever. Rich Shumaker
That's interesting. The Airtop-PC that I just received has an M.2 slot. In addition, the front of the chassis has a replaceable FACE module that would easily accommodate BNC type connectors. While it has one 16x PCIe slot, that's typically occupied with an nVidia GTX card.
Was thanked: 3 time(s) in 1 post(s)
Actually Blackmagic also has a MiniPcıExpress sdi and Hdmi input card but it is not listed on webpage. they only sell it for specific customers.
I would absolutely interested in knowing how well these work. I have a laptop with 1-2 m.2 slots and I'm looking to make it my mobile solution.
RichShumaker wrote:I found this today when I was researching capture devices. Yuan M.2 SDI Capture http://www.yuan.com.tw/e...di_hdv_b_m_keys_spec.htmThought you guys might enjoy it for tiny capture builds. I think it would make a great NDI remote capture box build. Drop it in a Intel NUC and off you go. If anyone has used it let me know as I am interested to know how it works. Since the bandwidth is there I think a 4K capture would be unbelievable in the M.2 form factor. I also think that is at least 2 years away if ever. Rich Shumaker Where can you purchase Yuan products??
ozgurozan wrote:Actually Blackmagic also has a MiniPcıExpress sdi and Hdmi input card but it is not listed on webpage. they only sell it for specific customers. How can we get more info on this? Just email them and ask?
Yes, I saw these. Id like to compare pricing.
mmmorlandotv wrote:Yes, I saw these. Id like to compare pricing. Do let us know what you find. I have an older AVer Media C127 in an old box that I presently used to capture from HDMI. I bring it into my Airtop-PC via NDI. Eventually, I'll add a mPCIe HDMI card to the Airtop. That would tidy up and simplify the situation, but they seem a bit pricey.
mmmorlandotv wrote:RichShumaker wrote:I found this today when I was researching capture devices. Yuan M.2 SDI Capture http://www.yuan.com.tw/e...di_hdv_b_m_keys_spec.htmThought you guys might enjoy it for tiny capture builds. I think it would make a great NDI remote capture box build. Drop it in a Intel NUC and off you go. If anyone has used it let me know as I am interested to know how it works. Since the bandwidth is there I think a 4K capture would be unbelievable in the M.2 form factor. I also think that is at least 2 years away if ever. Rich Shumaker Where can you purchase Yuan products?? I am working with Yuan right now. The M.2 requires a custom cable they do not provide, the SDI I think is standard 'mini' size but I am not sure. I have asked for pricing and availability and I will let you know what I find out. SaberPC has Yuan products and you can also find them on Amazon and Ebay. The M.2 seems to be an industrial needs product so they don't make that as end user available. Oh and M.2 and MiniPCI are different form factors so make sure you are able to use what you are looking at in your computer. Rich Shumaker
 1 user thanked RichShumaker for this useful post.
