SriJnanatma
#1 Posted : Wednesday, May 3, 2017 3:55:43 AM(UTC)
SriJnanatma
we wanted to run Windows on the highest Macbook Pro for vMix.
- is there any slow down on the thunderbolt ports when running windows on the Mac?
- is there any stability problems running windows on mac?
- and would the MAc with vMix be able to stream to the web channel and also playout a video to LED walls at the same time with no issues?
thank you
#2 Posted : Wednesday, May 3, 2017 5:02:37 AM(UTC)
This has been discussed many times on the forum already. Please use the "search" option for more information.
Not a very good idea imho. vMix is optimized for Windows and nVidia GTX.
SriJnanatma on 5/3/2017(UTC)
SriJnanatma
#3 Posted : Wednesday, May 3, 2017 5:04:25 AM(UTC)
SriJnanatma
sorry, thanks for informing, will check on it
thank you
#4 Posted : Wednesday, May 3, 2017 5:15:55 AM(UTC)
As the search function doesn't accept 3 letter word like "mac", use "bootcamp" as a keyword instead
SriJnanatma
#5 Posted : Wednesday, May 3, 2017 5:55:43 AM(UTC)
SriJnanatma
yes :), thanks.
