Hi there, I'm currently having issues with having multiple activators trigger across 1 single key on an xkeys xk-60. I'm trying to have an activator trigger the key red when the input is in the program feed, and then turn blue if the input is in the preview window. The default I have set up is for all keys to be off. This seems like it would be simple, but currently whatever activator I have lowest in the list seems to take priority with the other option not triggering at all, so I feel like I'm just messing something obvious up. Any help would be appreciated! Here are my current settings for the activators. I wanted to figure this out before adding the rest of my inputs in. Thanks, Sage
Hi Sage
a single button can only be used for a single action and the activator reflects only this action. Your button is either a trigger for preview or for program. It cannot be both at the same time. So you have to use 2 buttons : one for PVW and one for PGM. Then you can use activators accordingly.
Guillaume
