Facebook Live Stream Cuts Short
Hey All,
Testing some Live Stream stuff on FB and I'm finding that, regardless of what resolution I'm using, my stream is cut off after two minutes or so. VMix is recording it fine, but once I check the video in FB, it's usually just stops really early on.
Is anyone else having this issue?
Cheers.
Joined: 4/28/2017(UTC) Posts: 1 Location: Villa Park, IL
Do you have any music with your stream? Facebook will put a quick stop to it for copy right violations.
choehn wrote:Do you have any music with your stream? Facebook will put a quick stop to it for copy right violations. and one will not be able to try another one , FB just doesn't stop a stream they in fact block any future stream right away. vMix even tells you if you try to IMO there is another issue at hand
