Kaf
#1 Posted : Wednesday, September 28, 2016 11:24:39 AM(UTC)
Kaf
Hi everyone !
I have recently upgrade my system to Windows 10 and after the upgrade my RTMP input lag after a random time I have some dropped frame
Me and my friends use a lot of RTMP inputs to broadcast game with vmix, The players use OBS or Xsplit to stream the gameplay on our Nginx RTMP server and we display it with Vmix.
We usually add 8 RTMP sources.
We try to fix it with the Free edition and the HD, nothing change...
When I load just ONE RTMP source, No lag, run perfectly.
If I load TWO or THREE input, they lag/drop frame
No issue on Windows 7
I try on two differents computer with Windows 10, same issue, dropped frame after a couple of minutes, even if we try to "Reset" the Flash/RTMP input or restart VMIX.
I try some tweak, downgrade the Flash Player to version 22, change the RTMP server, uninstall the Flash security update... same issue.
To be sure we read the RTMP with VLC when we get the drop frame, VLC can easily load up to 8 RTMP video with no drop frame and the CPU usage is way better.
To the devlopper : Maybe we need a vMix upgrade to load RTMP without the FLASH component ? Maybe it's possible with ffmpeg ? Flash is heavy CPU load, but it's an other story :p
Thanks to the dev Team to make vMix great !
Kaf
#2 Posted : Sunday, October 2, 2016 10:36:26 AM(UTC)
Kaf
Yes, it use Flash Player, the same as Internet explorer use.
RTMP video seems to be read with the StrobeMediaPlayback.swf in the vmix folder
And sure, a FFMPEG play will cost less CPU ressources.
By the way I got 70% CPU usage with 8 720p videos and it works pretty well with my Windows 7 Setup.
Windows 10 is probably the cause.
Kaf
#3 Posted : Sunday, April 30, 2017 9:12:56 AM(UTC)
Kaf
Hello, I just try to load 4 RTMP sources in the new vMix 19 @ Windows 10.
Same issue, after a few minutes one or two sources drop frame and freeze :/
Any news of updating the Strobemediaplayback.swf ?
Thank you for your time.
#4 Posted : Sunday, April 30, 2017 9:50:43 AM(UTC)
Use VLC to ingest your RTMP streams and NDI them out to vMix with NDI Plugin for VLC
Kaf
#5 Posted : Sunday, April 30, 2017 10:23:02 AM(UTC)
Kaf
Thanks for the idea, but it's definitly way too complicated :p
With VLC I have to add the RTMP manually, sometimes we have more than 20 RTMP sources and it's a pain to do it manually :p (we use API script)
#6 Posted : Sunday, April 30, 2017 10:52:11 AM(UTC)
Why? Is it automatic in vMix?
You can easily make a VLC playlist with your 20 RTMP sources, share it with multiple VLC instances and simply switch sources from this playlist to feed vMix
But sorry, I thought you wanted something that works reliably and flawlessly...
#7 Posted : Sunday, April 30, 2017 1:42:40 PM(UTC)
de nada Ayo! ;o)
Kaf
#8 Posted : Sunday, April 30, 2017 4:56:41 PM(UTC)
Kaf
Thanks for your help.
I did some test with 8 RTMP Sources through RTMP > VLC > NDI > VMIX
Unfortunately this solution need more cpu ressources than the Flash Player vMix
Here some screen :
RTMP VLC NDI Solution :
RTMP FLASH :
I think I will stay with Windows 7 as long as it is not stable on Windows 10.
Thanks !
Kaf
#9 Posted : Tuesday, May 2, 2017 6:03:21 AM(UTC)
Kaf
I guess it's "OK" with a 2nd Computer, but I'm not sure a single ethernet can handle 8 NDI sources, maybe with "NIC Teaming" etc... but that's another story :)
#10 Posted : Tuesday, May 2, 2017 6:12:08 AM(UTC)
It depends on your feeds resolution and framerate.
Ex: a 1080p25 NDI is 100/125 Mbits
So 8 x 1080p25 would be a little too much for a single gigabit NIC. However you can still have 5 or 6 feeds from a second computer and the rest on the vMix host
#11 Posted : Wednesday, May 3, 2017 3:46:22 AM(UTC)
No. NDI is a broadcast quality protocol only (visually lossless)
