vmix, and latency w ptzoptics cameras
Thanks: 12 times Was thanked: 3 time(s) in 3 post(s)
I am coming from xsplit - where I have zero delay.
but have been doing the switch to vmix slowly -
I am noticing a real latency on my new ptzoptics cam.
I am trying to figure out how to resolve this.
It's a bit off putting - especially when the hosts of the show are watching a video on the in-room monitor.
Suggestions ?
Joined: 3/20/2014(UTC) Posts: 2,721   Location: Bordeaux, France Thanks: 243 times Was thanked: 795 time(s) in 589 post(s)
How do you use this cam? SDI? HDMI? Streaming protocol over ETH?
Joined: 3/30/2011(UTC) Posts: 308  Location: Portugal Thanks: 347 times Was thanked: 35 time(s) in 30 post(s)
Ethernet ... always have latency ..its not NDI... to reduce it, you have to use CBR bitrate and mjpeg encoding on the cameras... probably. use cat6 cables with a good gigabit switcher. to have zero latency ... have to use SDI HD outputs on PTZs SDI HD capture card.. and always use graphic card outputs for video outs.. vMix engine is on the GPU not on CPU :) use a good Nvidia GTX 1050 and up 2 gogs of ram or up. windows pro 1' 64 bits latest build 1703.
Cheers,
PFBM
I have the NVIDIA GEFORCE GTX970 and 16 gigs of ram.
I am using a USB 3.0 cable that came w the camera.
I have been using 4 logitech cameras for the past year - and have never seen a second of delay.
I realize these are higher end cameras - but I never thought there would be this much of a difference.
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 319 times Was thanked: 263 time(s) in 233 post(s)
iamralphsutton wrote:I have the NVIDIA GEFORCE GTX970 and 16 gigs of ram.
I realize these are higher end cameras - but I never thought there would be this much of a difference. You need to dig into the details to understand this and implement a solution. A USB camera can deliver a stream encoded in different ways. Logitech supports YUY2 (uncompressed) MJPEG or H264 encoding. YUY2 and MJPEG are frame-based so there's no latency to speak of. H264 is a group-of-frame (GOP) based compression scheme. It always introduced some latency. In the case of a USB camera using MJPEG or H264 was intended to allow the use of 1080p30 over a modest USB 2.0 connection. In the case of the new Brio webcam, MJPEG allows 4K30 over USB 3.0. The same holds true for Ethernet connected cameras. If you use H264 there will be latency. Be sure to set the encoding type in vMix when to create the source. Don't leave it at "default" which may be H264 for a network camera.
I have the ptzoptics set to 1920x1080 and the video encoding is MPEG
I have vMix also set to the same - both w an NTSC 30p setting as well
and there is a very noticeable lag.
I am also connected via a short USB 3.0 cable that came w the PTZoptics camera.
It's very frustrating.
I would appreciate any other ideas - as if this doesn't work - I will have to return the cameras - as well as go back to xSplit sadly.
as this was all part of a major upgrade plan for the studio.
iamralphsutton wrote:I have the ptzoptics set to 1920x1080 and the video encoding is MPEG If the vMix project also set to 1080p30? If the sources and project are different resolutions it can cause delay.
Everything is 1920 rt now.
Should I try and dumb it down to 720? Should that make a difference>?
iamralphsutton wrote:Everything is 1920 rt now.
It's worth a try. Although the stats indication in the lower left part of the vMix window should indicate if the system is excessively burdened. What are the render times & CPU usage being reported. If you use the camera in some other app do you see the same delay?
The system usage was 7% - and I have discovered that the delay is also in other programs.
So now I need to talk with ptzoptics to see why it's happening.
But thank you for your help.
