JonnyNoblett
#1 Posted : Wednesday, April 26, 2017 3:26:00 AM(UTC)
JonnyNoblett
I have a JSON file which returns a 6 digit code which related to the 6 digit name of an image - 123456.jpg
Is there a way I can use the digits to load an image in a xaml title e.g.
http://website.com/images/{0}.jpg where {0} is image1, image2, image3,... from the JSON file returning 123456, 678910, 111213, etc
#2 Posted : Wednesday, April 26, 2017 3:33:27 AM(UTC)
Hi
I don't know if XPath was fully implemented in vMix but you should try
concat(value,".jpg")
in the XPath query
Guillaume
JonnyNoblett on 4/26/2017(UTC)
#3 Posted : Wednesday, April 26, 2017 5:02:14 AM(UTC)
Have you actually tried it first ? because yes (using datasources )
JonnyNoblett
#4 Posted : Wednesday, April 26, 2017 6:04:03 AM(UTC)
JonnyNoblett
I did yes but it threw up an error. I will try replicating what I did to see what the error was - it may have been to do with the xaml file. I just made something basic in Title Designer with a single image.
#5 Posted : Wednesday, April 26, 2017 7:34:17 AM(UTC)
Try first maybe with an existing vMix title to check your datasource
in fact when the datasource is correct during setup you also should see the correct link appear when you specify the field
JonnyNoblett
#6 Posted : Wednesday, April 26, 2017 11:58:24 AM(UTC)
JonnyNoblett
I have managed to check it can pull from the data source using the method http://website.com/images/{0}.jpg
I have put it in manually using the title editor on the title but I need to work out how to edit the xaml so that the image source is the value "image" as listed in the JSON file - This will then hopefully pull the value under "image" as {0}
#7 Posted : Wednesday, April 26, 2017 12:14:39 PM(UTC)
If i understand correctly what you are trying to do , you can not use {0} in the xaml code as is
any image placeholder in a title can hold any image
For manual input you need to write the full link
JonnyNoblett
#8 Posted : Wednesday, April 26, 2017 4:31:20 PM(UTC)
JonnyNoblett
I managed to get it to work, it was something to do with the way i had setup the image within the xaml file.
I also wanted to do the same with some .svg image files but i don't think they are supported by vMix.
