Hi, Is it possible to add the possibility to have more than 4 zoom preset in the virtual set ? If i have 4 cam i cant use the dezoom and zoom on 4 pictures so its a bit useless ! For 4 cam we need 5 picture to have all 5 transition.
You can use the API commands to change all zoom levels anytime. You can also change any input in a virtualset anytime. So you can have a 10 cam production in a single virtualset very easily with some shortcuts.
@ Element III Perhaps you can add your support for this request which has already been made here: https://forums.vmix.com/...aspx?g=posts&t=10301It's always better to keep the same or similar request in one thread in order to garner support and/or discussion as opposed to spreading it out over multiple threads and why you are always encouraged to search the topic first (it just makes it easier for the developers to keep track of the most wanted features). Thanks. Ice
