Two same outputs with different audio
Someone who streams the same vmix production with different audio mix to a second streaming hoster/server on the same vMix machine? I see that it is possible two choose audio in live stream settings.
I try to find out if it's possible to have a simultaneous translated setting with one vmix machine.
Regards Andreas
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Andreas Check this post where I explained a potential solution I already used for multilingual streaming from a single PC (but with an external encoder) https://forums.vmix.com/....aspx?g=posts&t=8638I don't think it's possible to do it only with vMix using the channel selection in the destination stream tab as vMix doesn't seem to accept different settings for audio depending on destination. If you create a 2nd destination and change audio source for it, it will also change it for destination 1. Guillaume
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
We make this in the server side, upload only one stream with master bus a and bus b, and in the server with ffmpeg copy the video and map only one/two channel, using this way we only need a "small" upload and can make up to 6 languages and "unlimited" destination without add load in our master server.
