#1 Posted : Thursday, April 20, 2017 11:34:25 AM(UTC)
Hi!
If you want your remote guest to share his webcam and his screen with you, you can tell him to use Splitcam.
I think vMix to vMix (even with a 60 day trial version) is obviously a better solution but Splitcam is a decent solution
It allows to share and use a single webcam with multiple applications at the same time, but it also features video, image and desktop sharing. There's even a PiP mode which can be very handy to have a basic multiview layout!
Free. But displays ads for adult webcam services! (in the application UI, not the video content!)
It's compliant with all USB webcams, but also USB dongles like Magewell and last but not least with capture cards.
http://splitcamera.com/
Guillaume
rowby on 1/5/2018(UTC)
#2 Posted : Friday, April 21, 2017 9:28:54 AM(UTC)
Another cool software to use for a remote call with vMixCall is ManyCam.
ManyCam is a free webcam software and a video switcher that allows you to use your webcam on most applications simultaneously while you live stream or video chat.
ManyCam allows you to quickly switch between up to 12 video, audio and image sources. Use the pull-down menu in the source window to add another camera, a still image, a photo snapshot, a pre-recorded video, or your desktop as your video source. Choose to cut or slowly transition between different sources.
There's a free limited version (watermarked) with 2 sources perfect for trial.
https://manycam.com/
Guillaume
