i have a sony camera ( FDR-AX53 ) you can connect vmix through wireless and if so how to connect it.
Joined: 3/7/2012(UTC) Posts: 2,689  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
@ emad
My guess is NO, you will not be able to connect to vMix with the Sony FDR-AX53's Wi-Fi and NFC capabilities (at least not easily). AFAIK, those features of the camera allow you use your smartphone or tablet to control the camcorder, as well as wirelessly transfer files to your mobile device and even stream live to Ustream (which requires a Wi-Fi router or smartphone capable of tethering). I suppose it might be theoretically possible but it would most likely require a hack of some sort to be able to intercept the stream. You would be best to use the HDMI output of the camera via the appropriate capture device for best results with vMix. Just my thoughts.
