Filter twitter tweets based on a text.
Joined: 4/1/2017(UTC) Posts: 14   Location: Leuven-Belgium Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Hi
I want to overlay in real time some tweets from my profile. I see I can turn on to do that instantly but it does that with any tweet from my profile.
Is there a way to filter the tweets based on a text?
In my specific situation I only want to show tweets in real time starting with the text "is now playing ♫ : "
I need this to show the track title I'm currently playing in Traktor Pro (a DJ software). The only way to extract the current playing track is using RADR which publishes my tracks in real time on twitter. There is nothing I can change in that process.
Thank you
Joined: 3/20/2014(UTC) Posts: 2,720   Location: Bordeaux, France Thanks: 243 times Was thanked: 796 time(s) in 590 post(s)
Hi I don't think you can do this with vMixSocial unless you can use a unique and personal hashtag The solution you're looking for is certainly here : https://dev.twitter.com/rest/publicwhere you can build your own app using JSON and the search api, and then use it as a datasource in vMix. Hope this helps Guillaume
 2 users thanked DWAM for this useful post.
Thank you, I'll take a look into that.
