Error when changing recording folder after Windows 10 Creators update *FIXED*
Thanks: 74 times Was thanked: 4 time(s) in 3 post(s)
I didn't use multicorder and replay lately, but today I found that I can't change default recording folder in settings, replay folder and multicorder folder. vMix says that drive is unhandled. And the same on another computer. With another disk and system. After Windows 10 Creators update? I have vMix 4k, 19.0.0.42.
Downgrading to vMix 18 will help? Where can one find it to install?
vMix 18 would be in your Documents folder where the EXE install files from vMix get downloaded to my default.
I use 4K, and have been able to change Replay and Multicorder folder settings since upgrading to 19.0.0.42 , but I'm running Win 8.1.
 1 user thanked SportsNetUSA.net for this useful post.
Thanks: 106 times Was thanked: 2 time(s) in 2 post(s)
We have same problem after Windows 10 Creators update at the weekend - must have introduced a bug - good old M$Soft... vMix 19.0.0.42
 1 user thanked ON.tv Channels for this useful post.
We have to wait until Martin returns from NAB
 1 user thanked Zetor1980 for this useful post.
Thanks for the reply... I sort of expected that would be the case with NAB round the corner! Just when I was thinking the updates on 5 PCs had more or less gone without a hitch. Now it's time to see what MS have added to their ever more aggressive snooping program - they appear to turn back all options 'on' we previously turned off and reset to their default - plus I'm sure they will have added a few more 'peepers!
I can confirm this issue after Windows Creator's update (on both 18.0.0.65 and 19.0.0.42).
Zetor1980, may I suggest that you clarify in the topic's title. For instance by changing it to "Error when changing recording folder after Windows 10 Creators update"
 1 user thanked richardgatarski for this useful post.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
It only happens with the "browse" function. If you type in the address, or "copy-paste" directly it works fine.
Just some more details on the bug,
Steve
 2 users thanked stevespaw for this useful post.
Steve
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
Hi guys,
Could you try the following test update to see if it resolves the problem: [Update now available, check vMix Update]
Martin vMix
 3 users thanked admin for this useful post.
Thank You, Martin. Problem solved.
Agree, problem solved - just checked. Thanks!
Thanks .43 has now been posted as an official update.
Thanks Martin You're a star! Hope you have a successful trip to NAB...
Was going to post about this as noticed yesterday on my laptop when testing something. great that It wasn't me and its resolved quickly Thanks Martin
