2 Pages12>
Ittaidv
#1 Posted : Monday, April 17, 2017 11:28:26 AM(UTC)
Ittaidv
Elgato has some new toys. It looks like you can configure the buttons as you like.
https://www.elgato.com/en/gaming/stream-deck
If I understand it well, you can also upload custom icons. So you could take a screenshot of every shot, downsize it to 72x72 pixels, and upload it to the controller.
This way, you have a visual representation of every shot on every button.
For a 5 camera production this doesn't look bad if it works as advertised :)
Amokka
#2 Posted : Monday, April 17, 2017 12:17:31 PM(UTC)
Amokka
Was thanked: 18 time(s) in 13 post(s)
I agree this looks to be almost perfect.
From the information I have found about it at this point, I would think it is possible to use the controller with vMix in two ways:
1) Hotkeys
2) Call a custom command (i.e. CSCRIPT or Powershell) that in turn invokes the vMix API
As far as I can see, StreamDeck doesn't support MIDI control commands (yet). :-(
Obviously, I would like StreamDeck to have a tighter integration into vMix - preferably with 2-way communication so that Icons/functions on the StreamDeck will update dynamically to reflect status from vMix (i.e. a Button for "start/stop stream" will switch between showing "Start Stream" and "Stop Stream" or the like).
I would also like a version of StreamDeck to have more than 15 buttons - or - be able to have more than one StreamDeck connected to a system at the same time. But I guess this is up to Elgato and not vMix :-)
Jon
hellokitty
#3 Posted : Wednesday, April 19, 2017 3:03:44 AM(UTC)
hellokitty
You could use Bome Midi Translator Pro, and turn the ouputs into Midi Signals.
Amokka
#4 Posted : Wednesday, May 24, 2017 10:24:03 AM(UTC)
Amokka
Why would you do that, when you can send the hotkey directly to vMix?
It would just be another layer of complexity without any of benefits.
Mathijs
#5 Posted : Wednesday, May 24, 2017 12:43:56 PM(UTC)
Mathijs
Maybe to be able to keep it working when vMix is not the in focus application on windows.
Normally when using keyboard shortcuts and you use a mouse to do something in another application, you lose the shortcuts until vMix is selected to be in focus.
It is really easy to design your own control panel by the way, get a teensy, some lighted buttons like the adafruit 16mm ones, wires, resistors and depending on the number of buttons you want, shift registers. After some funtime drilling a housing and soldering, you can program it with easy code using the arduino ide with teensy plugin. Tell the IDE it is a midi device and the only thing needed is write code to read the inputs and send a midi command if a button is pressed. Also make it read midi so activators can light the leds.
I have made some small panels with 4 lighted buttons on them to put on a desk so clients can switch between 4 inputs, while being as simple as it can be.
Sondrey
#6 Posted : Thursday, May 25, 2017 8:04:00 PM(UTC)
Sondrey
Was thanked: 18 time(s) in 10 post(s)
Hey guys!
We have recieved this device and have been able to program a vMix "driver" for it :)
This "driver" will be able to show animations and timers etc. on the button screens.
Updates coming soon!
thanks 6 users thanked Sondrey for this useful post.
SportsNetUSA.net on 5/25/2017(UTC), Ittaidv on 6/9/2017(UTC), stevespaw on 6/13/2017(UTC), RichShumaker on 6/22/2017(UTC), mjgraves on 8/5/2017(UTC), tlaurencin on 2/22/2018(UTC)
richardgatarski
#7 Posted : Friday, May 26, 2017 3:05:39 AM(UTC)
richardgatarski
Sondrey wrote:
Hey guys!
Whow! Can't wait :P
LAJDigital
#8 Posted : Thursday, June 8, 2017 9:00:14 AM(UTC)
LAJDigital
Just picked up one of these today and will be watching this thread with great interest.
shibbycribby
#9 Posted : Saturday, June 24, 2017 6:33:18 AM(UTC)
shibbycribby
Sounds great has there been any update on the driver you spoke about Sondrey? Would be great to have active animations for the live camera, really loving the stream deck so far, got it hooked up along with a apem t-bar and it works a treat.
stevespaw
#10 Posted : Saturday, June 24, 2017 10:22:36 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
How are you using this T-bar?
Can you share with us?
Steve
shibbycribby
#11 Posted : Wednesday, June 28, 2017 6:37:26 AM(UTC)
shibbycribby
Hey Steve,
Yeah of course, its actually a adaptation of a potentiometer project using a teensy board to convert the signals into a midi controller. Just follow this though:
http://little-scale.blog...usb-midi-controller.html
Then instead of wiring up the pot switch it out for the atem t-bar (theres a guy on ebay doing a decent one for £50 at the moment http://www.ebay.co.uk/it...418:g:RiQAAOSwcLxYEcpB). Just make sure to solder the wire ordering correct so it matches the schematics of the tbar as its different to the pot.
Once your done just hook the teensy board up to the pc, pop vmix open and it should show up as a midi device, just assign the teensy board as SetFader shortcut and it should let you fade back and forth just like the x-keys tbar.
thanks 1 user thanked shibbycribby for this useful post.
stevespaw on 8/5/2017(UTC)
RickyTerzis
#12 Posted : Saturday, August 5, 2017 11:43:02 AM(UTC)
RickyTerzis
Hi...i am a new user here. I think maybe to be able to keep it working when vMix is not the in focus application on windows.
assembly circuits
dark_ata
#13 Posted : Saturday, August 5, 2017 12:07:09 PM(UTC)
dark_ata
@RickyTerzis if you uses midi controller always work , if vmix is not in focus also work
#14 Posted : Saturday, August 5, 2017 1:17:47 PM(UTC)
@ RickyTerzis
That is the advantage of using a MIDI Controller or external device like the supported X-Keys devices.
As dark_ata states "always" ON.
If you don't have a device to test with, you could use a smartphone or tablet on the same network and connect to the "Web Controller" as they behave the same.
Personally, I prefer the tactile nature of a Controller over a tough screen, but it's an option for you to test out.
rinaldo
#15 Posted : Sunday, August 6, 2017 6:51:41 PM(UTC)
rinaldo
Sondrey wrote:
Hey guys!
Any news?
Thremir
#16 Posted : Sunday, August 6, 2017 8:35:10 PM(UTC)
Thremir
We have been occupied with doing a huge project using HTML and casparcg and the stream deck driver has sadly been postponed until mid September.
Cheers,
Håvard
Njastad Webshop
nowski
#17 Posted : Saturday, August 12, 2017 2:15:34 PM(UTC)
nowski
I use a Korg Nano Controller, 9 channels each with fader, three buttons and a knob, plus transport control, use MIDI mapping and stick on labels:
http://www.gear4music.co...IDI-Controller-Black/G8L
Whats really cool about this is that we just migrated from an adhoc systme, but I can use the same MIDI controls, just reassigned for Vmix, so no muscle memory issues for the one man show, or you could use this for more controls.
http://www.gear4music.co...-Studio-MIDI-Controller/
Rogue_Danar
#18 Posted : Friday, September 8, 2017 10:35:14 PM(UTC)
Rogue_Danar
Cheers,
Håvard
Njastad Webshop
I can't wait for the release - it looks like it'll be awesome!
fthomas137
#19 Posted : Wednesday, September 20, 2017 11:00:31 AM(UTC)
fthomas137
I'd like to see if there is more news on this too. I've picked one up on the pretense vMix will be supporting it.
Frank
RobLambert
#20 Posted : Thursday, September 21, 2017 8:08:59 PM(UTC)
RobLambert
Guys,
This seems to do the same thing as Xkeys controllers; but, i am sure there are many important differences. I sure will want one or the other. Is there a good place where i can study up on the differences to make a good decision.
Rob
2 Pages12>
