Hardware Compatibility
Sapphire Asus Laptop Thunderbolt 3 Caution!!
Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
Hi Evereyone, I just bought a Asus ROG GL702VM a little better than the GL502VM . Well it can be a hit or a miss when it comes to what speed you will get with your thunderbolt 3 port either 20gbits/ or 40gbits . Asus is very vague and sketchy. Heres a Forum Post that will help a bit. https://rog.asus.com/for...lt-3-port-in-the-GL502VMI cancelled my order.
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
For vMix purposes, you only need 10gbps for up to 8 1080p cameras, so 20gbps should be more than enough. Why do you need the full 40gbps?
Martin vMix
Joined: 1/2/2017(UTC) Posts: 34  Location: United States Thanks: 15 times Was thanked: 16 time(s) in 11 post(s)
I am using the GL502VM with Sonnet Echo T3 into the Thunderbolt 3 connection and I have a Decklink Duo 2 inside it. So 4 cameras going strong. I have also successfully came out of the T3 extra port on the Sonnet device into a Startech T3 to T1/T2 device and used it with Mini Recorder and all is perfect. I bet it is your cable. The Belkin T3 Cable is rated 20GB Per Second not 40GB. Be careful what cable you order.
Maybe i want to use my kona 4 to capture 4k 60fps with my sonnet echo express 3d. when the sonnet device gets upgraded to thunderbolt 3 next month. Asus clearly states on there website that it is 40 gbits, for the ROG GL702, when it is not, for all of them, and it is very hard to find out wich ones are. The kona card is 8 lane pcie 2.0. Im just advising the Forum that they might not get what they think they are buying. Plus i might add another card into the Sonnet echo express 3d and capture more at the same time, or run a 4k 60fps monitor off of the sonnet. its gonna need that 40 gbits.
Rank:: Advanced Member
Joined: 9/17/2013(UTC) Posts: 173  Location: Norway Thanks: 10 times Was thanked: 56 time(s) in 29 post(s)
I have done some testing with this and a Decklink Quad 2 card.
I used an ASUS G750JW with thunderbolt 1 10Gbps, an ASUS GL502VM with thunderbolt 3 20Gbps, an Akitio Thunder2 and an Thunder3.
The results are very linear.
On my Thunderbolt 1 10Gbps config I can get maximum 3x 1080p60 inputs before starting to drop frames at source. On my Thunderbolt 3 20Gbps config I can get maximum 6x 1080p60 inputs before starting to drop frames at source.
We also did some massive tries at getting a MSI TITAN GT73VR to work with this, which does have full 40Gbps TB3, but never got any decklink card to work with it. (Possibly TB3 NVM firmware needed, but MSI hasn't released any.)
If you use 1080p30, 1080i or 720p and/or live in the PAL region (50/25) you should get many more inputs working due to bandwidth. 8x 720p60 worked perfectly on my Thunderbolt 1 config.
 5 users thanked Thremir for this useful post.
Thank You Thremir for the Great Info! I like good details.
Back with more testing; Asus G752VS with Akitio Thunder3 which allegedly has 40gbps TB3 (see images for chip details): Suprisingly enough; same results as ASUS GL502VM with thunderbolt 3 20Gbps: Max 6x 1080p60 Might this be because many (including the Thunder 3) of the thunderbolt enclosures are 4x while the card is 8x? I don't have any knowledge about how the PCIe gen 3.0 4x works with the PCIe gen 2.0 8x of the Quad 2 card. Maybe the physical pinout for the PCIe bandwidth is missing while the actual thunderbolt bandwidth is there? I put together a small album of relevant images: http://imgur.com/a/FDOwAIs there any PCIe 8x boxes out there with a thunderbolt 3 interface? (EDIT: Found one: http://www.sonnettech.co.../echoexpressse1tb3.html)EDIT: Is PCIe 3.0 4x a limitation of the Thunderbolt 3 connection itself? Can it be converted/adapted to 2.0 8x?  ^from the official thunderbolttechnology.net website DOUBLEEDIT: Does this mean it doesn't matter if you get the 20gbps or 40gbps chip, or even a thunderbolt 2 enclosure as long as a) your card does not support PCIe 3.0 or b) you are not going to daisychain more devices? Would two Decklink Duo 2 cards in 2 thunder3 chassises daisychained work as expected?
 2 users thanked Thremir for this useful post.
I was mainly stating that they are kind of fooling people with the "thunderbolt 3!" when alot of the laptops have chipsets that are running at Thunderbolt 2 speed across a USB C connector. That link i provided has all the info on the chipsets. Even Intel Thunderbolt 3 website canot be relied on, it's a bad situation cause i would like to purchase a laptop, but not right now.
 1 user thanked hellokitty for this useful post.
yeh Egpu are dramaticly hampered, maybe in a few years you would want the latest gpu in a thunderbolt 3 expansion box, well it wont run very well at thunderbolt 2 speed.
Thanks: 185 times Was thanked: 20 time(s) in 17 post(s)
I know this is an old thread, but still: this page is quite informative, about how to get the most out of a Thunderbolt3 connection on selected laptops. "eGPU.io user builds listed as 32Gbps-TB3 are confirmed to offer full Thunderbolt 3 bandwidth performance."
 2 users thanked Ario for this useful post.
