Joined: 4/6/2017(UTC) Posts: 16  Location: Adelaide, SA Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
We just bought a simple audio mixer and have been setting up the shortcuts and I thought I'd unplug it and plug it back in to see if it still works. I can't get it working unless I restart vMix but what if you're in the middle of a stream? It's not really a viable option. The mixer has a mini usb port that looks like it's just begging to slip out. Anyone got any ways to get it back responsive if it were to come unplugged. Also got a X-Keys 128 which would suck if that became unplugged.
Cheers, Trent.
Yeah, the present situation that a MIDI controller is unusable when it is unplugged during a stream or whenever vMix is running. The present sitation is very unfortunate, and I really hope that somekind of autodetection of reconnecting of MIDI controller would be possible in vMix. This would help alot in many situations.
So I would say a new feature request:
+1 for auto detection of reconnection of MIDI controllers
 2 users thanked stigaard for this useful post.
stigaard wrote:Yeah, the present situation that a MIDI controller is unusable when it is unplugged during a stream or whenever vMix is running. The present sitation is very unfortunate, and I really hope that somekind of autodetection of reconnecting of MIDI controller would be possible in vMix. This would help alot in many situations.
+1 for auto detection of reconnection of MIDI controllers +1 not only for MIDI also for USB Soundcards
Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
Please also add more functions that are available in the section of light activators in MIDI, currently there are only few
Joined: 6/4/2014(UTC) Posts: 81  Location: USA Thanks: 40 times Was thanked: 9 time(s) in 9 post(s)
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
Thanks: 10 times Was thanked: 1 time(s) in 1 post(s)
+100000
this should be top priority! Right now it makes expensive hardware unusable and all workflow a lot slower and difficult to operate! Please fix this :)
+1 (to reconnecting midi devices)
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
+ 1
(perhaps this thread should be moved to Feature Requests)
Joined: 1/13/2010(UTC) Posts: 5,317  Location: Gold Coast, Australia Was thanked: 4719 time(s) in 1617 post(s)
Hi guys,
Unfortunately this is a limitation of windows. While a program is running and a MIDI device is disconnected, that program will not be notified when it is reconnected and any attempts to connect to the driver will connect to the original instance (and fail).
Therefore, the only fix is on the hardware side to make sure it is not unplugged! ;)
Martin vMix
@admin that is very unfortunate.
How about the case where the usb bus is overloaded and the MIDI controllers stops working, is there any way to avoid this problem?
Quote:How about the case where the usb bus is overloaded and the MIDI controllers stops working, is there any way to avoid this problem? Just add a PCI(-E) card for USB having its own controller
admin wrote:Unfortunately this is a limitation of windows. While a program is running and a MIDI device is disconnected, that program will not be notified when it is reconnected and any attempts to connect to the driver will connect to the original instance (and fail). That's unfortunate. Would a possible workaround to be a "bridge app" that takes the connection to the MIDI device and passes the exchange to/from vMix? Then, in case the connection is lost, the operator could click a button that stops and restarts the bridge app.
Joined: 12/20/2016(UTC) Posts: 190   Location: Milano Was thanked: 21 time(s) in 13 post(s)
richardgatarski wrote:admin wrote:Unfortunately this is a limitation of windows. While a program is running and a MIDI device is disconnected, that program will not be notified when it is reconnected and any attempts to connect to the driver will connect to the original instance (and fail). That's unfortunate. Would a possible workaround to be a "bridge app" that takes the connection to the MIDI device and passes the exchange to/from vMix? Then, in case the connection is lost, the operator could click a button that stops and restarts the bridge app. In my first project with Arduino, I used Hairless midiserial to send midi messages to vmix through USB. That software is just a "bridge" but the behaviour is the same: if you disconnect a midi controller and you reconnect it, Hairless midiserial stop to work, this is the reason why I changed the firmware in Arduino to transform it in a plug and play midi controller avoiding a "bridge" (with the same problem).
Quote:Then, in case the connection is lost, the operator could click a button that stops and restarts the bridge app. Nice idea, but in the end I think the result will be the same. If you stop and restart the bridge app, it's connection will be lost in vMix the same way. Maybe with a dev board like the teensy 3.6 we could fabricate a hardware midi buffer, as it has two usb connections. Plug that in, connect a powered USB hub to it and make it send the commands trough it's own devices. That way you only have to make sure one usb connector is not disconnected, but on the other hand it would be adding a big single point of failure too. I never had USB cables disconnected by mistake during a production, but I had USB ports going down by getting too much power drawn. Multiple Xkeys panels can do that when the power to the hub gets disconnected or in my case is plugged into a socket that did go nowhere. In that case it is not a catastrophe either, because you always have the mouse and keyboard of the system to finish the show. Maybe for the OP it is better to harden that mini usb connection by glueing a cable to the housing with some epoxy, or even replace the connector by a fullsize USB-B if there is room enough.
Thanks: 27 times Was thanked: 19 time(s) in 16 post(s)
Mathijs wrote:Quote:Maybe for the OP it is better to harden that mini usb connection by glueing a cable to the housing with some epoxy, or even replace the connector by a fullsize USB-B if there is room enough. When we use a laptop + a capture card in a thunderbolt enclosure, I always put a piece of duck tape on the thunderbolt cable that is connecting to the laptop, so someone doesn't unplug it by accident. However, it is really unfortunate if there is no way to recover from a disconnect. We also use AJA's U-TAP's (SDI -> USB) and if I recall correctly, a disconnect is recoverable without restarting vMix.
Joined: 2/1/2018(UTC) Posts: 9  Location: Germany Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
Martin vMix Is there now a fix for the problem in Windows 10 or a doable workaround?
Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
You could try Bome Midi Translator. Have it forward only. In theory this should work. We had stability issues with the app, so we didn't use it. But it may work for you.
