Hardware Compatibility
4k camera cropping to a 720p production?
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
Here's the use case. I have a panel discussion with 4 panelists sitting at a dais facing the audience. I want to use a single 4k camera in the aisle to provide both an overview shot of the entire panel, and close ups of individuals through vMix cropped virtual inputs. I will be recording/streaming in 720p.
So far, my testing with a Logitech Brio has been disappointing (perhaps there are ways of tweaking this setup). I would like my next test to be with my 4k Sony FDR-x1000v action camera as a 4k input. I currently use a regular Magewell hdmi>USB adapter, but that only captures 1080p.
Has anyone tried the new Magewell USB Capture HDMI Plus adapter? Any thoughts of how well this will work? Are there better capture adapter alternatives?
Ideally, I would like to have cropping functionality similar to what Mevo is promoting, but setting up cropped multi-views of the panelists would be sufficient.
Any thoughts from folks who are doing this kind of setup are appreciated.
@ AlanZ
What are your system specs (laptop or desktop) and which version of vMix are you using? AFAIK, you'll need at least vMix 4K to capture a 4K image, even if you are only outputting 720p, and outside of Brio's connectivity, I believe you'll need a 4K capable capture card.
Quote:Are there better capture adapter alternatives? A PCI-e 4K capture card like those from BMD Quote:Any thoughts of how well this will work? Not as well as you expect I guess. Your vMix project is set for UHD so that you can input your UHD source, although you stream at 720p Then when you use the cropped portion of the image it is upscaled by at least factor 3 > this will be very blurry At the end everything is downscaled to 720p but the blurry will remain I have not tested this myself (no 4K capture device either) but as far as I understand how vMix works, you won't be able to input a 4K source unless your project is set to 4K. I regularly use the method you're talking about in Resolve or Premiere: it works because we can import UHD footage in a 1080p or 720p project, so there is absolutely no loss when use the zoom factor. But I don't think it's the same with vMix. Let us know, I'm interested to get your feedback if you experiment this. Guillaume
DWAM wrote: I have not tested this myself (no 4K capture device either) but as far as I understand how vMix works, you won't be able to input a 4K source unless your project is set to 4K.
At least in reference to the Logitech Brio webcam this is not the case. You can set the webcam to 4K in a project that's set to something less, say 720p30. You can then use vMix to reposition the shot to use just a portion of the Brio scene. However, doing this seems to cause some delay in the webcam stream.
I am running vMix 4k edition, on a laptop computer.
The computer I tested on was an MSI with an i7 6700 quad core processor and an Nvidia 960 onboard graphics. Tomorrow, I will be switching that out to an Asus with an i7 7700 quad core with Nvidia 1050 graphics onboard.
mjgraves wrote: At least in reference to the Logitech Brio webcam this is not the case. You can set the webcam to 4K in a project that's set to something less, say 720p30.
MJ, If my Brio input was set to 3840x and the project set to 720p, I get the delay even without cropping the image.
I just did a test with a Brio on a desktop computer...
I changed the project to 2160p instead of my previous 720p Then I set the recording and external devices to 720p
I then used vMix's zoom shortcuts to magnify the Brio's image... it worked MUCH better than when the project was set to 720P...
I will do more testing tomorrow, but the results are encouraging. The Brio still lags behind a C920 by a very little bit...
The key here may very well be to match the project properties to that of the highest resolution camera, regardless of the intended outputs.
 1 user thanked AlanZ for this useful post.
AlanZ wrote:I currently use a regular Magewell hdmi>USB adapter, but that only captures 1080p. Has anyone tried the new Magewell USB Capture HDMI Plus adapter? Any thoughts of how well this will work? Are there better capture adapter alternatives? FYI, the Magewell USB Capture HDMI Plus is limited to 1080p60 capture resolution. Although it will accept a 4K input signal it will scale it down for transmission over the USB3 bus. They are introducing (soon) a version which will capture up to 4Kp30 with 4:2:0 colour sampling over USB3, which is about the limit for uncompressed video over USB3.0. That version will accept a wider range of 4K input signals, up to 4:4:4 at 60p.
 1 user thanked zenvideo for this useful post.
zenvideo wrote:FYI, the Magewell USB Capture HDMI Plus is limited to 1080p60 capture resolution. Although it will accept a 4K input signal it will scale it down for transmission over the USB3 bus. They are introducing (soon) a version which will capture up to 4Kp30 with 4:2:0 colour sampling over USB3, which is about the limit for uncompressed video over USB3.0. That version will accept a wider range of 4K input signals, up to 4:4:4 at 60p. The use of 4:2:0 sampling is a pity. Down-sampling 4:4:4 to 4:2:0 is a terrible waste. It would be nice if there was silicon to support some simple compression scheme, like that used in NDI. That would allow them to retain 4:2:2 sampling over the USB 3.0 link. Generally better for production purposes.
Joined: 8/5/2013(UTC) Posts: 281  Location: Poland Thanks: 29 times Was thanked: 40 time(s) in 37 post(s)
Capture 4K to USB 3 in 4:2:0 color space is possible with Inogeni 4K >> USB3.0 device. https://inogeni.com/4k-usb3-0/Very nice box, works great in HD (like Magewell dongle). Could not test it in 4K so far (no 4K camera ;)
Joined: 10/1/2016(UTC) Posts: 117  Thanks: 88 times Was thanked: 52 time(s) in 31 post(s)
When I switched over to vmix it took some testing to figure out, but I use the BMD 4K pci declink mini recorder with a 4K gopro5 for situations when we have no room for production cameras, large tripods or need to do a single operator stream in a very small/tight location. I usually setup 4 or 5 virtual inputs with different zoom and pan points. Also often use an ipad with OSCtouch to control preview pan and zoom via midi. So far I have found 4K UHD input into a 1080 project streamed at 720p works best for my setup. With pretty crisp video, you do need pro or 4K version of vmix to bring in the source at 4K.
Next time I do a single 4K camera setup I will try to get a video of my setup/settings and share on the forums.
This is a feature I used in Wirecast 7 all the time on our Macs, so I am glad I got it working in vMix.
-SHMD
 2 users thanked SHMD for this useful post.
