Joined: 1/13/2010(UTC) Posts: 5,345  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
19.0.0.38
* Fixed sped up audio from vMix Call guest after returning from a brief internet outage. Audio will now catch up almost immediately.
* Fixed InputBusXAudio Activator Events * Fixed some issues decoding audio in RTSP streams from Matrox Monarch * Fixed Title Editor left hand menu scrolling when resizing window
 7 users thanked admin for this useful post.
19.0.0.41
* Added New "YouTube Live Stream Now" streaming destination. Login only once to stream directly to Stream Now on your YouTube channel. Stream Key is handled automatically, even if your streaming settings change.
* Added New Periscope/Twitter destination that supports streaming to Periscope and Twitter directly without needing the mobile app.
* Improved descriptions on Facebook Settings window to make the options a bit clearer
19.0.0.42
* Fixed DataSource Format field reverting to {0} in edit window * Changed preset dropdown menu to only show 25 most recent presets * Updated Periscope/Twitter API and made option to stream to both Periscope and Twitter the default in the Periscope/Twitter settings
 5 users thanked admin for this useful post.
19.0.0.43
* Fixed a bug on Windows 10 Creators Update when browsing for a recording or replay folder.
 4 users thanked admin for this useful post.
19.0.0.46
* NEW Overlay buttons added below transition buttons in vMix to show any active overlay channels. These buttons can also be used to transition in the last used input on a particular channel. If users prefer not to see these buttons they can be hidden from Settings -> Options
* NEW Channel Mappings option added to Settings -> Shortcuts -> MIDI Settings for X-Keys devices. This allows selecting a custom channel for X-Keys devices to prevent conflicts when using multiple X-Keys and/or a combination of MIDI and X-Keys controllers. (Only X-Keys can be changed using this option, as standard MIDI devices have fixed channels unless they provide the option to change this within the driver software)
* Added shortcuts for Video Delay Start/Stop Recording * Added input numbers to dropdown in List tab. * Fixed bug where long running vMix Call inputs may take a long time to close. This should also improve CPU usage and stability of calls. * Prevented use of Teredo connections when using vMix Call which tend to have higher latency. * Fixed problem with ReplayMarkCancel shortcut * Fixed all Global MIDI shortcuts being disabled if one Local MIDI shortcut was present. This will now mirror the standard keyboard behaviour where only a global shortcut with the exact channel/note and value as a local shortcut will be disabled. * Fixed problem playing some .MPG files
 17 users thanked admin for this useful post.
DWAM on 5/5/2017(UTC), Amokka on 5/5/2017(UTC), avsoundguy on 5/5/2017(UTC), sinc747 on 5/5/2017(UTC), madness on 5/5/2017(UTC), ask on 5/5/2017(UTC), corporatejames on 5/5/2017(UTC), stigaard on 5/6/2017(UTC), Video Dave on 5/7/2017(UTC), Stavlin on 5/7/2017(UTC), ON.tv Channels on 5/7/2017(UTC), GoGo on 5/7/2017(UTC), NeObr on 5/8/2017(UTC), thisguy on 5/9/2017(UTC), stergi on 5/10/2017(UTC), bcolgate on 5/11/2017(UTC), Zetor1980 on 5/12/2017(UTC)
19.0.0.47
* Fixed some issues with new Overlay buttons not showing correct state in some situations.
19.0.0.49
* NEW BETA VLC option under Add Input -> Stream This uses a special version of VLC that allows bringing in any supported stream formats (such as RTMP) directly into vMix. It is now recommended for RTMP streams instead of the existing Flash/RTMP option which relies on the Adobe Flash Player and is less reliable as a result.
* Fixed bug where hidden PTZ inputs were not moving into position when selected using a MIDI controller. * SetImage API now supports URLs
 10 users thanked admin for this useful post.
19.0.0.50
VLC Stream Input: * Fixed audio sync issue * Fixed blank video issue on MJPEG streams * Enabled deinterlace tickbox in Input Settings for streams that are interlaced.
19.0.0.53
* Made some minor changes and adjustments to Facebook API support * vMix now properly enforces the Facebook policy requirement of not streaming to other providers when using the API.
19.0.0.54* New Shortcuts: ListAdd ListRemove ListRemoveAll ListExport ListShuffle SetInputName SetTextColour (For additional information see http://www.vmix.com/help...utFunctionReference.html ) * API XML updated to include: Fullscreen Edition Filename of last preset loaded List information (items in list, selected and enabled status) Replay information (speed, timecode, recording/live enabled, selected a and b cameras) * Fixed error in Camera input preventing MultiCorder from recording 59.94 inputs in some formats * Added workaround for AJA output interrupt issue causing excessive frame drops under high system load
 13 users thanked admin for this useful post.
DWAM on 6/20/2017(UTC), stigaard on 6/20/2017(UTC), niemi on 6/20/2017(UTC), DYosua on 6/20/2017(UTC), sinc747 on 6/20/2017(UTC), corporatejames on 6/20/2017(UTC), Stavlin on 6/21/2017(UTC), Video Dave on 6/22/2017(UTC), avsoundguy on 6/25/2017(UTC), hubert17 on 6/26/2017(UTC), bcolgate on 6/28/2017(UTC), ON.tv Channels on 7/4/2017(UTC), SHMD on 8/3/2017(UTC)
