Thanks: 23 times Was thanked: 3 time(s) in 3 post(s)
I want to setup a playlist of inputs to run through before a scene starts, may be videos, images titles.
I started to make one with triggers but could find a way to end the loop once I was ready to manually change inputs and I was stuck in a vicious loop that only stopped when I changed the scene. Is there a way to do this with triggers or other?
Thank
@ JonnyNoblett
Are you using the "Playlist" feature? You can easily set up a "Playlist" (an automated switching feature in vMix) with any Inputs you have available and can stop the "Playlist" at anytime and transition to any Input manually, so I'm not exactly clear why you are using "Triggers" and getting yourself into a "loop" unnecessarily. Can you elaborate further?
