Virtual Inputs thumbnail disappeared
Rank:: Advanced Member
Thanks: 30 times Was thanked: 1 time(s) in 1 post(s)
I've created a few virtual inputs based on a multicam input I had created. But I think that since I deleted the original, they no longer show the thumbnail view in the inputs window. A mild frustration, but is there any way to fix this, other than recreating the original input, and all the virtual inputs? Can you turn a virtual input into an original?
Also - is a virtual input the way to go when you want to duplicate an input (e.g. in order to tweak some settings for a different shot) or is there a different way I should be using?
Ha, yeah - unfortunately too late. I've got it in a previously saved file, but I can't see any way to copy an input, or is there?
Quote:but I can't see any way to copy an input, or is there? I don't think so. Using presets is the best way
Joined: 3/7/2012(UTC) Posts: 2,688  Location: Canada Thanks: 33 times Was thanked: 513 time(s) in 481 post(s)
grDancer wrote:I've created a few virtual inputs based on a multicam input I had created. But I think that since I deleted the original, they no longer show the thumbnail view in the inputs window. A mild frustration, but is there any way to fix this, other than recreating the original input, and all the virtual inputs? Can you turn a virtual input into an original?
Also - is a virtual input the way to go when you want to duplicate an input (e.g. in order to tweak some settings for a different shot) or is there a different way I should be using? Short answer is YES! Depending on the nature of your original Input may determine exactly how you need to proceed, but typically, you can re-input your original Input onto the Virtual Input by using the "Change" feature of that Input's Settings (Cog wheel-> General-> Change Button). Hope that helps some and answers your question. Ice
IceStream wrote:grDancer wrote:I've created a few virtual inputs based on a multicam input I had created. But I think that since I deleted the original, they no longer show the thumbnail view in the inputs window. A mild frustration, but is there any way to fix this, other than recreating the original input, and all the virtual inputs? Can you turn a virtual input into an original?
Also - is a virtual input the way to go when you want to duplicate an input (e.g. in order to tweak some settings for a different shot) or is there a different way I should be using? Short answer is YES! Depending on the nature of your original Input may determine exactly how you need to proceed, but typically, you can re-input your original Input onto the Virtual Input by using the "Change" feature of that Input's Settings (Cog wheel-> General-> Change Button). Hope that helps some and answers your question. Ice Kinda/not really! So - these "orphan" virtual inputs that now no longer have the thumbnail image in the inputs workspace, there's no way to get the thumbnail back?
@grDancer
You are essential creating a new one when you use the "Change" function, which will have its own thumbnail, but you preserve any "MultiView" settings you may have previously set up on the Virtual copy. So in that sense it's not the original thumbnail but if you use the same source again it should be the same.
IceStream wrote:@grDancer
Ice AHA! Thanks. I didn't want to act rashly in case I misunderstood, but yes, I confirm that using the "change" and selecting colour magically recreated the original thumbnail as it was. Thanks a lot!!
