Rinsky
#1 Posted : Tuesday, April 11, 2017 7:04:05 PM(UTC)
Rinsky
is there a way to disable the overlays on some inputs?
For example: I want to use external CasparCG graphics, but don't want them on my Instant Replay Channels. How do I achieve this without having to untick/tick the overlay every single time when I go into an Instan Replay?
I know that it would be a workaround to implement the CasparCG graphics as a multiview for each input, but it's a lot and when I add an input I could forget to implement the multiview on it or just don't have the time to do it.
So...is there a way to achieve this?
#2 Posted : Tuesday, April 11, 2017 8:02:21 PM(UTC)
@ Rinsky
Although I am partial to "MultiView" for this, an alternative might be to use "Triggers" on the Instant Replay Input "OnTransitionIn -> OverlayInputAllOff".
(You would likely want to also set-up "Triggers" on the Inputs that you do want the overlays ON to reinstate them, otherwise you are clicking the overlay button for them anyways)
Rinsky on 4/11/2017(UTC)
Rinsky
#3 Posted : Tuesday, April 11, 2017 9:26:39 PM(UTC)
Rinsky
Seems like a lotta work if I have to set it up on all inputs and then it's basically the same as it would be with Multiview.
But I'll give the "OnTransitionIn -> OverlayInputAllOff" a try, thank you!
#4 Posted : Tuesday, April 11, 2017 9:28:36 PM(UTC)
You only need to add this trigger for your replay
Rinsky
#5 Posted : Tuesday, April 11, 2017 9:40:54 PM(UTC)
Rinsky
I added following triggers:
OnTransitionIn -> OverlayInputAllOff - > Preview
and
OnTransitionOut -> OverlayInputXIn -> CasparCG Input
and it did the trick!
Thank you very much!
