NDI
NDI on Intel coreM Processors
Rank:: Advanced Member
Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
Hi guys!
Anyone tried running NDI Connect or Vmix to generate NDi with a computer running Intel CoreM5 processor?!
I've not personally tried it, but Core M CPUs all appear to support SSSE3 (required by all NDI applications) and AVX (required by many NewTek applications like Connect), I would expect that the applications would run. Does it have enough processing power is a different question. These processors are designed for tablets and low power applications, they certainly wouldn't be my first choice in a CPU for processing video, but perhaps for your needs it might work.
Kane Peterson NewTek
kane wrote:I've not personally tried it, but Core M CPUs all appear to support SSSE3 (required by all NDI applications) and AVX (required by many NewTek applications like Connect), I would expect that the applications would run. Does it have enough processing power is a different question. These processors are designed for tablets and low power applications, they certainly wouldn't be my first choice in a CPU for processing video, but perhaps for your needs it might work.
Kane Peterson NewTek Hi Kane, The ideia is to work as a one 1080P source encoder for a camera. I would plug The Item CoreM pc with a USB3 capture card.
NDI
