stigaard
#1 Posted : Saturday, April 8, 2017 4:23:32 PM(UTC)
stigaard
Denmark
Hi vMixers,
I discovered a bug in the Instant Replay module when exporting clips got cut unintended whenever it uses footage from two recorded video files.
I've made a little video showing the bug:
Jens Stigaard
#2 Posted : Sunday, April 9, 2017 12:11:29 AM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
Hi Jens,
Thanks for the report and putting together the video.
It does indeed sound like the bug is related to there being a couple of dropped frames between the two segments causing the export to miss
the remaining footage.
To test this theory try exporting an event that runs over two video segments earlier on in the game. If those two segments have no dropped frames
I suspect it will work as expected.
stigaard
#3 Posted : Sunday, April 9, 2017 2:59:24 AM(UTC)
stigaard
Denmark
Hi Martin,
I've not been able to replicate the bug from other instances of replay footage.
I have looked through the (3 hours+) footage of the day after, and there is no problems with the gaps between the 20 minutes video file segments in the recordings.
Very strange.
If I meet a situation where I see the problem again, I'll try to make a better investigation of it.
Jens Stigaard
