pesi
#1 Posted : Saturday, April 8, 2017 11:52:24 AM(UTC)
pesi
Canada
I have an announcement graphic (e.g. webcast will start soon...) and I was wondering how I could play an audio file (music) along with it.
Right now I can either play/show one or the other but not both together(?)
I tried using the audio as an Overlay but no joy...
Wirecast used to do this using 'layers' which are not a feature in vMix (?)
Any advice?
xaver
#2 Posted : Saturday, April 8, 2017 11:56:37 AM(UTC)
xaver
I would set the Graphic to programm and play the audiofile without preview or program
only Audio ON
thanks 1 user thanked xaver for this useful post.
pesi on 4/8/2017(UTC)
stigaard
#3 Posted : Saturday, April 8, 2017 12:01:00 PM(UTC)
stigaard
Denmark
I would bring in the audio file, create a virtual input of it, and then add the still graphic in the Multi-view tab under settings for the input.
thanks 1 user thanked stigaard for this useful post.
pesi
#4 Posted : Saturday, April 8, 2017 12:01:30 PM(UTC)
pesi
Canada
program? Where is that?
#5 Posted : Saturday, April 8, 2017 12:12:00 PM(UTC)
You have been a member since:: 3/20/2014(UTC)
Just press Play arrow of your audio input
or create a trigger for your graphics : OnTransitionIn > Play > audio input
SportsNetUSA.net
#6 Posted : Saturday, April 8, 2017 12:44:32 PM(UTC)
SportsNetUSA.net
Many ways to do as have been posted. Did you trying playing the audio file and using the graphic as an overlay? That's simple and works.
pesi
#7 Posted : Saturday, April 8, 2017 2:07:34 PM(UTC)
pesi
Canada
The method(s) suggested by DWAM worked great - simple solution. Thanks all!
Guest (6)
