hellokitty
#1 Posted : Friday, April 7, 2017 3:16:31 PM(UTC)
hellokitty
My Kona LHI captures and works great in AJA Control Room, but when i bring it into Vmix there is audio Distortions going on? in AJA control panel, there signal is 1080p 60 coming in, But my Vmix session i have set at 59.94 could that be the issue? I need it set at 59.94 for other cameras and devices, well Please Help Thank You.
SportsNetUSA.net
#2 Posted: : Friday, April 7, 2017 6:09:46 PM(UTC)
SportsNetUSA.net
In Audio Settings (in vMix) for the Kona LHI what is the format set to?
thanks 1 user thanked SportsNetUSA.net for this useful post.
hellokitty on 4/7/2017(UTC)
hellokitty
#3 Posted : Friday, April 7, 2017 6:28:55 PM(UTC)
hellokitty
48000 32 bit float 2 channels
hellokitty
#4 Posted : Friday, April 7, 2017 6:44:02 PM(UTC)
hellokitty
wierd thing is , it starts out fine, then after about 2 minutes, it starts getting distorted.
stevespaw
#5 Posted : Friday, April 7, 2017 6:53:17 PM(UTC)
stevespaw
Was thanked: 75 time(s) in 57 post(s)
I did not know that card was still supported, I have one on the shelf that I may have to break out.
Steve
thanks 1 user thanked stevespaw for this useful post.
hellokitty
#6 Posted : Friday, April 7, 2017 7:12:44 PM(UTC)
hellokitty
Ok so i used a Blackmajic desighn hdmi to sdi micro converter, and put it into the kona breakout box, no problems in vmix yet. but the hdmi port on the breakoutbox still has the audio issues with only Vmix. AJA Control Panel works with both inputs no problem.
Guest (5)
